mka
 - Sep 26, 2013
after reading the forum and guides, I've learned that I probably won't need an L2ARC SSD for my SOHO and Ram is always better.
But... what about persistence of the cache? My FreeNAS Server is powered down almost every night and powered up on demand in the late afternoon every other day. I've noticed the FreeNAS samba performance is quite slow after it's initial boot up... directory access times take a long time a first, but getting dramatically better in the first hour.
My explanation is: at every boot-up ZFS is trying to fill its volatile cache. After some time most accesses can be filled from cache and after shutdown ZFS has to start from scratch.
Whould an SSD configured as L2ARC help in this scenario cause it's persistence storage and non-volatile keep their cached date between shutdowns? Or wouldn't it be filled at all cause there is enough ram available? Or can this be adjusted?
Thank you!
Thank you!
