Is there a reason my l2arc (128GB SSD) is reporting ~380GB?
JR Gonzalez Explorer Joined Aug 29, 2014 Messages 64 Apr 11, 2015 #1 Is there a reason my l2arc (128GB SSD) is reporting ~380GB?
HoneyBadger actually does care Administrator Moderator iXsystems Joined Feb 6, 2014 Messages 5,112 Apr 11, 2015 #2 Is the disk correctly identified as 120GB in the other management pages and/or the command line? L2ARC is compressed in 9.3 IIRC so if you have highly compressible data in there the webGUI might be reporting the "uncompressed equivalent" size.
JR Gonzalez Explorer Joined Aug 29, 2014 Messages 64 Apr 11, 2015 #3 Yes. It is properly identified as 128GB. I get the compression but going from 128GB to 380GB? Singularity compression algorithm?
HoneyBadger actually does care Administrator Moderator iXsystems Joined Feb 6, 2014 Messages 5,112 Apr 11, 2015 #4 JR Gonzalez said: Yes. It is properly identified as 128GB. I get the compression but going from 128GB to 380GB? Singularity compression algorithm? Click to expand... 3:1 isn't unreasonable depending on what you're storing. You'd be surprised how well a Windows Server install compresses.
jgreco Resident Grinch Joined May 29, 2011 Messages 18,680 Apr 12, 2015 #5 HoneyBadger said: 3:1 isn't unreasonable depending on what you're storing. You'd be surprised how well a Windows Server install compresses. Click to expand... IME very well especially once you drop it in the recycle bin.
