Hello all,
I had 2x 500gb samsung 960 evo NVME ssds collecting dust and thought why not use them as l2arc for my vm storage ssd pool (used via iscsi for a hyperv cluster).
Said and done the l2arc is in service since 2 days and its doing nothing (I think?).
under the "reports --> zfs" tab I can see that after adding an l2arc the utilization shown in the first chart is next to non-existent.
It says "max l2arc 973MB" and l2arc hit ratio is at 0.06 mean and 1.37 max. Am I looking at the wrong chart? What can I do to utilize the l2arc?
Or should I just get rid of the l2arc?
The system:
Xeon Silver 4210 10c 20t
192 GB DDR4 Reg ECC
Intel X540 SFP+ dual port 10gbps nic
10x 4tb HDD (mirrored vdevs)
6x 500gb samsung 860 evo SATA ssd (mirrored vdevs) + 2x 500gb samsung 960 evo NVME ssd as l2arc
Thanks in advance for your help!
EDIT: ARC hit ratio looks good as far as I can tell with a mean of 96.06.
EDIT 2: completed the ssd definitions
The system:
192 GB DDR4 Reg ECC
