- Apr 16, 2020
Under Kubernetes Settings / Advanced Settings there is "Node IP", "Route v4 Interface" and "Route v4 Gateway". If I alter Route V4 gateway to point to a different router on my LAN (it goes out through a VPN Firewall) and type curl if(p)config.io into say a Sonarr container I get an external address on the VPN connection. The main scale gateway is pointing at my primary router. But I get an address on the VPN router connection - which is good. BUT traffic out on the internet coming into the VPN does not go anywhere. It just vanishes - because its going to the primary gateway rather than back to the VPN gateway. As soon as I change the scale gateway then the port shows as open from outside down the VPN connection.
Any thoughts?
The problem is that changing the TrueNAS Scale gateway changes the default IP for any containers. I can't even use a different VLAN as Scale can only have a single default IP. I could run a VM with the containers BUT then I get all the access permissions grief trying to get access to the Scale Storage
With Core, each Jail has its own network stack, so I could do what I wanted - not so with Scale
Any thoughts?
