I am getting this error :
kernel: mfi0: IOCTL 0x40704d07 not handled
several times a day.
Anyone know the cause of it? I don't seem to have a bad disk. Wondering what is wrong?
Here is the storcli dump:
Generating detailed summary of the adapter, it may take a while to complete.
CLI Version = 007.1316.0000.0000 Mar 12, 2020
Operating system = FreeBSD 12.3-RELEASE-p5
Controller = 0
Status = Failure
Description = None
Detailed Status :
Ctrl Status ErrCd ErrMsg
0 Failed 255 Failed to get Bus Information
Basics :
Controller = 0
Model = ServeRAID M5014 SAS/SATA Controller
Serial Number = SV12302325
Current Controller Date/Time = 07/25/2022, 02:17:21
Current System Date/time = 07/25/2022, 02:17:23
SAS Address = 500605b0038012b0
PCI Address = NA
Mfg Date = 05/29/12
Rework Date = 00/00/00
Revision No = 71B
Version :
Firmware Package Build = 12.13.0-0179
Firmware Version = 2.130.383-2854
Bios Version = 3.29.00_4.14.05.00_0x05290000
Preboot CLI Version = 04.04-020:#%00009
WebBIOS Version = 6.0-52-e_48-Rel
NVDATA Version = 2.09.03-0046
Boot Block Version = 2.02.00.00-0000
Bootloader Version = 09.250.01.219
Driver Name = N/A
Driver Version = N/A
Bus :
Vendor Id = 0x1000
Device Id = 0x79
SubVendor Id = 0x1014
SubDevice Id = 0x3C7
Host Interface = PCI-E
Device Interface = SAS-6G
Pending Images in Flash :
Image name = No pending images
Status :
Controller Status = Optimal
Memory Correctable Errors = 0
Memory Uncorrectable Errors = 0
ECC Bucket Count = 0
Any Offline VD Cache Preserved = No
BBU Status = 0
PD Firmware Download in progress = No
Support PD Firmware Download = No
Lock Key Assigned = No
Failed to get lock key on bootup = No
Lock key has not been backed up = No
Bios was not detected during boot = No
Controller must be rebooted to complete security operation = No
A rollback operation is in progress = No
At least one PFK exists in NVRAM = No
SSC Policy is WB = No
Controller has booted into safe mode = No
Controller shutdown required = No
Supported Adapter Operations :
Rebuild Rate = Yes
CC Rate = Yes
BGI Rate = Yes
Reconstruct Rate = Yes
Patrol Read Rate = Yes
Alarm Control = Yes
Cluster Support = No
BBU = Yes
Spanning = Yes
Dedicated Hot Spare = Yes
Revertible Hot Spares = Yes
Foreign Config Import = Yes
Self Diagnostic = Yes
Allow Mixed Redundancy on Array = No
Global Hot Spares = Yes
Deny SCSI Passthrough = No
Deny SMP Passthrough = No
Deny STP Passthrough = No
Support more than 8 Phys = Yes
FW and Event Time in GMT = No
Support Enhanced Foreign Import = Yes
Support Enclosure Enumeration = Yes
Support Allowed Operations = Yes
Abort CC on Error = Yes
Support Multipath = Yes
Support Odd & Even Drive count in RAID1E = No
Support Security = Yes
Support Config Page Model = Yes
Support the OCE without adding drives = Yes
Support EKM = Yes
Snapshot Enabled = No
Support PFK = No
Support PI = No
Support Ld BBM Info = No
Support Shield State = No
Block SSD Write Disk Cache Change = No
Support Suspend Resume BG ops = No
Support Emergency Spares = Yes
Support Set Link Speed = No
Support Boot Time PFK Change = No
Support JBOD = No
Disable Online PFK Change = No
Support Perf Tuning = No
Support SSD PatrolRead = Yes
Real Time Scheduler = Yes
Support Reset Now = Yes
Support Emulated Drives = No
Headless Mode = Yes
Dedicated HotSpares Limited = No
Point In Time Progress = No
Extended LD = No
Support Uneven span = No
Support Config Auto Balance = No
Support Maintenance Mode = No
Support Diagnostic results = No
Support Ext Enclosure = No
Support Sesmonitoring = No
Support SecurityonJBOD = No
Support ForceFlash = No
Support DisableImmediateIO = No
Support LargeIOSupport = No
Support DrvActivityLEDSetting = No
Support FlushWriteVerify = No
Support CPLDUpdate = No
Support ForceTo512e = No
Support discardCacheDuringLDDelete = No
Support JBOD Write cache = No
Support Large QD Support = No
Support Ctrl Info Extended = No
Support IButton less = No
Support AES Encryption Algorithm = No
Support Encrypted MFC = No
Support Snapdump = No
Support Force Personality Change = No
Support Dual Fw Image = No
Support PSOC Update = No
Support Secure Boot = No
Support Debug Queue = No
Support Least Latency Mode = Yes
Support OnDemand Snapdump = No
Support Clear Snapdump = No
Support PHY current speed = No
Support Lane current speed = No
Support NVMe Width = No
Support Lane DeviceType = No
Support Extended Drive performance Monitoring = No
Enterprise Key management :
Capability = Supported
Boot Agent = Not Available
Configured = No
Supported PD Operations :
Force Online = Yes
Force Offline = Yes
Force Rebuild = Yes
Deny Force Failed = No
Deny Force Good/Bad = No
Deny Missing Replace = No
Deny Clear = No
Deny Locate = No
Support Power State = No
Set Power State For Cfg = No
Support T10 Power State = No
Support Temperature = Yes
NCQ = No
Support Max Rate SATA = No
Support Degraded Media = No
Support Parallel FW Update = No
Support Drive Crypto Erase = No
Support SSD Wear Gauge = No
Supported VD Operations :
Read Policy = Yes
Write Policy = Yes
IO Policy = Yes
Access Policy = Yes
Disk Cache Policy = Yes
Reconstruction = Yes
Deny Locate = No
Deny CC = No
Allow Ctrl Encryption = No
Enable LDBBM = No
Support FastPath = No
Performance Metrics = Yes
Power Savings = No
Support Powersave Max With Cache = No
Support Breakmirror = No
Support SSC WriteBack = No
Support SSC Association = Yes
Support VD Hide = No
Support VD Cachebypass = No
Support VD discardCacheDuringLDDelete = No
Support VD Scsi Unmap = No
HwCfg :
ChipRevision = B4
BatteryFRU = N/A
Front End Port Count = 0
Backend Port Count = 8
BBU = Present
Alarm = Disable
Serial Debugger = Present
NVRAM Size = 32KB
Flash Size = 8MB
On Board Memory Size = 256MB
CacheVault Flash Size = NA
TPM = Absent
Upgrade Key = Present
On Board Expander = Absent
Temperature Sensor for ROC = Absent
Temperature Sensor for Controller = Absent
Upgradable CPLD = Absent
Upgradable PSOC = Absent
Current Size of CacheCade (GB) = 0
Current Size of FW Cache (MB) = 96
Policies :
Policies Table :
Policy Current Default
Predictive Fail Poll Interval 300 sec
Interrupt Throttle Active Count 16
Interrupt Throttle Completion 50 us
Rebuild Rate 30 % 30%
PR Rate 30 % 30%
BGI Rate 30 % 30%
Check Consistency Rate 30 % 30%
Reconstruction Rate 30 % 30%
Cache Flush Interval 4s
Flush Time(Default) = 4s
Drive Coercion Mode = 1GB
Auto Rebuild = On
Battery Warning = On
ECC Bucket Size = 15
ECC Bucket Leak Rate (hrs) = 24
Restore Hot Spare on Insertion = Off
Expose Enclosure Devices = On
Maintain PD Fail History = On
Reorder Host Requests = On
Auto detect BackPlane = SGPIO/i2c SEP
Load Balance Mode = Auto
Security Key Assigned = Off
Disable Online Controller Reset = Off
Use drive activity for locate = Off
Boot :
BIOS Enumerate VDs = 1
Stop BIOS on Error = On
Delay during POST = 4
Spin Down Mode = None
Enable Ctrl-R = No
Enable Web BIOS = Yes
Enable PreBoot CLI = Yes
Enable BIOS = Yes
Max Drives to Spinup at One Time = 4
Maximum number of direct attached drives to spin up in 1 min = 120
Delay Among Spinup Groups (sec) = 2
Allow Boot with Preserved Cache = Off
High Availability :
Topology Type = None
Cluster Permitted = No
Cluster Active = No
Defaults :
Phy Polarity = 0
Phy PolaritySplit = 0
Strip Size = 128 KB
Write Policy = WB
Read Policy = No Read Ahead
Cache When BBU Bad = Off
Cached IO = Off
VD PowerSave Policy = Controller Defined
Default spin down time (mins) = 30
Coercion Mode = 1 GB
ZCR Config = Unknown
Max Chained Enclosures = 16
Direct PD Mapping = No
Restore Hot Spare on Insertion = No
Expose Enclosure Devices = Yes
Maintain PD Fail History = Yes
Zero Based Enclosure Enumeration = No
Disable Puncturing = Yes
EnableLDBBM = No
DisableHII = No
Un-Certified Hard Disk Drives = Allow
SMART Mode = Mode 6
Enable LED Header = No
LED Show Drive Activity = No
Dirty LED Shows Drive Activity = No
EnableCrashDump = No
Disable Online Controller Reset = No
Treat Single span R1E as R10 = No
Power Saving option = Enabled
TTY Log In Flash = No
Auto Enhanced Import = No
BreakMirror RAID Support = No
Disable Join Mirror = No
Enable Shield State = No
Time taken to detect CME = 60 sec
Capabilities :
Supported Drives = SAS, SATA
RAID Level Supported = RAID0, RAID1(2 or more drives), RAID5, RAID6, RAID00, RAID10(2 or more drives per span), RAID50, RAID60
Enable JBOD = No
Mix in Enclosure = Allowed
Mix of SAS/SATA of HDD type in VD = Not Allowed
Mix of SAS/SATA of SSD type in VD = Not Allowed
Mix of SSD/HDD in VD = Not Allowed
SAS Disable = No
Max Arms Per VD = 32
Max Spans Per VD = 8
Max Arrays = 128
Max VD per array = 16
Max Number of VDs = 64
Max Parallel Commands = 1008
Max SGE Count = 80
Max Data Transfer Size = 8192 sectors
Max Strips PerIO = 42
Max Configurable CacheCade Size(GB) = 0
Max Transportable DGs = 0
Enable Snapdump = No
Enable SCSI Unmap = Yes
FDE Drive Mix Support = No
Min Strip Size = 8 KB
Max Strip Size = 1.000 MB
Scheduled Tasks :
Consistency Check Reoccurrence = 168 hrs
Next Consistency check launch = 07/30/2022, 03:00:00
Patrol Read Reoccurrence = 168 hrs
Next Patrol Read launch = 07/30/2022, 03:00:00
Battery learn Reoccurrence = 672 hrs
Next Battery Learn = 08/20/2022, 16:00:00
OEMID = Lenovo
Drive Groups = 2
TOPOLOGY :
DG Arr Row EID:Slot DID Type State BT Size PDC PI SED DS3 FSpace TR
0 - - - - RAID1 Optl N 464.729 GB dsbl N N none N N
0 0 - - - RAID1 Optl N 464.729 GB dsbl N N none N N
0 0 0 :255 9 DRIVE Onln N 464.729 GB dsbl N N none - N
0 0 1 :255 11 DRIVE Onln N 464.729 GB dsbl N N none - N
1 - - - - RAID6 Optl N 10.913 TB dsbl N N none N N
1 0 - - - RAID6 Optl N 10.913 TB dsbl N N none N N
1 0 0 252:0 8 DRIVE Onln N 2.727 TB dsbl N N none - N
1 0 1 :255 10 DRIVE Onln N 2.727 TB dsbl N N none - N
1 0 2 252:1 12 DRIVE Onln N 2.727 TB dsbl N N none - N
1 0 3 252:3 13 DRIVE Onln N 2.727 TB dsbl N N none - N
1 0 4 252:2 14 DRIVE Onln N 2.727 TB dsbl N N none - N
1 0 5 :255 15 DRIVE Onln N 2.727 TB dsbl N N none - N
DG=Disk Group Index|Arr=Array Index|Row=Row Index|EID=Enclosure Device ID
DID=Device ID|Type=Drive Type|Onln=Online|Rbld=Rebuild|Optl=Optimal|Dgrd=Degraded
Pdgd=Partially degraded|Offln=Offline|BT=Background Task Active
PDC=PD Cache|PI=Protection Info|SED=Self Encrypting Drive|Frgn=Foreign
DS3=Dimmer Switch 3|dflt=Default|Msng=Missing|FSpace=Free Space Present
TR=Transport Ready
Virtual Drives = 2
VD LIST :
DG/VD TYPE State Access Consist Cache Cac sCC Size Name
0/0 RAID1 Optl RW Yes NRWBD - ON 464.729 GB
1/1 RAID6 Optl RW Yes NRWBD - ON 10.913 TB
VD=Virtual Drive| DG=Drive Group|Rec=Recovery
Cac=CacheCade|OfLn=OffLine|Pdgd=Partially Degraded|Dgrd=Degraded
Optl=Optimal||dflt=Default|RO=Read Only|RW=Read Write|HD=Hidden|TRANS=TransportReady|B=Blocked|
Consist=Consistent|R=Read Ahead Always|NR=No Read Ahead|WB=WriteBack|
AWB=Always WriteBack|WT=WriteThrough|C=Cached IO|D=Direct IO|sCC=Scheduled
Check Consistency
Physical Drives = 8
PD LIST :
EID:Slt DID State DG Size Intf Med SED PI SeSz Model Sp Type
252:0 8 Onln 1 2.727 TB SATA HDD N N 512B ST3000DM001-1CH166 U -
252:1 12 Onln 1 2.727 TB SATA HDD N N 512B HGST HUS724030ALA640 U -
252:2 14 Onln 1 2.727 TB SATA HDD N N 512B ST3000DM001-1ER166 U -
252:3 13 Onln 1 2.727 TB SATA HDD N N 512B HGST HUS724030ALA640 U -
:255 10 Onln 1 2.727 TB SATA HDD N N 512B ST3000DM001-1ER166 U -
:255 9 Onln 0 464.729 GB SATA HDD N N 512B WDC WD5000AVDS-61U7B1 U -
:255 15 Onln 1 2.727 TB SATA HDD N N 512B ST3000DM001-1ER166 U -
:255 11 Onln 0 464.729 GB SATA HDD N N 512B WDC WD5000AVDS-61U7B1 U -
EID=Enclosure Device ID|Slt=Slot No.|DID=Device ID|DG=DriveGroup
DHS=Dedicated Hot Spare|UGood=Unconfigured Good|GHS=Global Hotspare
UBad=Unconfigured Bad|Sntze=Sanitize|Onln=Online|Offln=Offline|Intf=Interface
Med=Media Type|SED=Self Encryptive Drive|PI=Protection Info
SeSz=Sector Size|Sp=Spun|U=Up|D=Down|T=Transition|F=Foreign
UGUnsp=UGood Unsupported|UGShld=UGood shielded|HSPShld=Hotspare shielded
CFShld=Configured shielded|Cpybck=CopyBack|CBShld=Copyback Shielded
UBUnsp=UBad Unsupported|Rbld=Rebuild
Enclosures = 1
Enclosure LIST :
EID State Slots PD PS Fans TSs Alms SIM Port# ProdID VendorSpecific
252 OK 4 4 0 0 0 0 1 - SGPIO
EID=Enclosure Device ID |PD=Physical drive count |PS=Power Supply count|
TSs=Temperature sensor count |Alms=Alarm count |SIM=SIM Count ||ProdID=Product ID
BBU_Info :
Model State RetentionTime Temp Mode MfgDate Next Learn
iBBU08 Optimal 48 hours + 32C 4 2018/04/16 2022/08/20 16:48:27
Mode 4: 48+ Hrs retention with a non-transparent learn cycle
and balanced service life.
Controller = 0
Status = Failure
Description = None
Detailed Status :
Basics :
Controller = 0
PCI Address = NA
Mfg Date = 05/29/12
Revision No = 71B
Version :
Driver Name = N/A
Bus :
Vendor Id = 0x1000
Device Id = 0x79
Status :
BBU Status = 0
Rebuild Rate = Yes
CC Rate = Yes
BGI Rate = Yes
Alarm Control = Yes
BBU = Yes
Spanning = Yes
Support EKM = Yes
Support PFK = No
Support PI = No
Support JBOD = No
Headless Mode = Yes
Extended LD = No
Configured = No
Force Online = Yes
Force Offline = Yes
Force Rebuild = Yes
Deny Clear = No
Deny Locate = No
NCQ = No
Read Policy = Yes
Write Policy = Yes
IO Policy = Yes
Access Policy = Yes
Deny Locate = No
Deny CC = No
Enable LDBBM = No
Power Savings = No
HwCfg :
ChipRevision = B4
BatteryFRU = N/A
BBU = Present
Alarm = Disable
NVRAM Size = 32KB
Flash Size = 8MB
TPM = Absent
Policies :
Policies Table :
PR Rate 30 % 30%
BGI Rate 30 % 30%
Auto Rebuild = On
Boot :
Enable Ctrl-R = No
Enable BIOS = Yes
High Availability :
Cluster Active = No
Defaults :
Phy Polarity = 0
Strip Size = 128 KB
Write Policy = WB
Cached IO = Off
EnableLDBBM = No
DisableHII = No
SMART Mode = Mode 6
Capabilities :
Enable JBOD = No
SAS Disable = No
Max Arrays = 128
Max SGE Count = 80
Scheduled Tasks :
OEMID = Lenovo
Drive Groups = 2
TOPOLOGY :
TR=Transport Ready
Virtual Drives = 2
VD LIST :
Check Consistency
Physical Drives = 8
PD LIST :
Enclosures = 1
Enclosure LIST :
BBU_Info :
