Hello again,
Checking my email this morning, I found a new message from my server telling me the following;
So I did a search on the forums and found that previous posts required smartctl -a -q noserial /dev/da1 information as well as camcontrol devlist to help diagnose what was going on. So here's the smartctl output;
And here's the camcontrol output;
Any help diagnosing what components are failing would be greatly appreciated. In my signature is my system set-up (hardware and zpool config). I run scrubs regularly. I'm also getting a critical error when logging into the GUI on the same drive in regards to temperature (set up by me to warn me if any drives were potentially getting too hot);
I am currently running version FreeNAS-9.3-STABLE-201506042008. I do have an update available, but haven't gotten around to implementing.
trinity.WORKGROUP kernel log messages: (da1:mps0:0:1:0): READ(16). CDB: 88 00 00 00 00 01 05 ca 4a 28 00 00 00 e0 00 00 length 114688 SMID 677 command timeout cm 0xffffff8000b32368 ccb 0xfffffe0040dfa000 (noperiph:mps0:0:4294967295:0): SMID 1 Aborting command 0xffffff8000b32368 (da1:mps0:0:1:0): READ(16). CDB: 88 00 00 00 00 01 05 ca 4b 08 00 00 00 e0 00 00 length 114688 SMID 222 command timeout cm 0xffffff8000b0dc70 ccb 0xfffffe0040dea000 (da1:mps0:0:1:0): READ(16). CDB: 88 00 00 00 00 01 05 ca 4b 08 00 00 00 e0 00 00 length 114688 SMID 222 terminated ioc 804b scsi 0 state c xfer 0 (da1:mps0:0:1:0): READ(16). CDB: 88 00 00 00 00 01 05 ca 4a 28 00 00 00 e0 00 00 (da1:mps0:0:1:0): CAM status: Command timeout (da1:mps0:0:1:0): Retrying command (da1:mps0:0:1:0): READ(16). CDB: 88 00 00 00 00 01 05 ca 4a 28 00 00 00 e0 00 00 (da1:mps0:0:1:0): CAM status: SCSI Status Error (da1:mps0:0:1:0): SCSI status: Check Condition (da1:mps0:0:1:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) (da1:mps0:0:1:0): Retrying command (per sense data) (da1:mps0:0:1:0): WRITE(10). CDB: 2a 00 00 40 01 b0 00 00 08 00 (da1:mps0:0:1:0): CAM status: SCSI Status Error (da1:mps0:0:1:0): SCSI status: Check Condition (da1:mps0:0:1:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) (da1:mps0:0:1:0): Retrying command (per sense data) -- End of security output --
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST3000DM001-9YN166
Firmware Version: CC4H
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Jul 3 04:25:12 2015 MDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 584) seconds.
capabilities: (0x73) SMART execute Offline immediate.
Auto Offline data collection on/off supp ort.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 338) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 129540688
3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 140
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 079 060 030 Pre-fail Always - 94950705
9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 14737
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 140
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 1 1 1
189 High_Fly_Writes 0x003a 098 098 000 Old_age Always - 2
190 Airflow_Temperature_Cel 0x0022 064 060 045 Old_age Always - 36 (Min/Max 29/39)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 138
193 Load_Cycle_Count 0x0032 014 014 000 Old_age Always - 173788
194 Temperature_Celsius 0x0022 036 040 000 Old_age Always - 36 (0 23 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 8413h+28m+22.461s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 191979086624575
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 216679946591166
SMART Error Log Version: 1
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error
# 1 Short offline Completed without error 00% 14599 -
# 2 Extended offline Completed without error 00% 14581 -
# 3 Short offline Completed without error 00% 14479 -
# 4 Short offline Completed without error 00% 14385 -
# 5 Short offline Completed without error 00% 14289 -
# 6 Extended offline Completed without error 00% 14272 -
# 7 Short offline Completed without error 00% 14170 -
# 8 Short offline Completed without error 00% 14008 -
# 9 Short offline Completed without error 00% 13887 -
#10 Extended offline Completed without error 00% 13869 -
#11 Short offline Completed without error 00% 13767 -
#12 Short offline Completed without error 00% 13647 -
#13 Short offline Completed without error 00% 13551 -
#14 Extended offline Completed without error 00% 13533 -
#15 Short offline Completed without error 00% 13431 -
#16 Short offline Completed without error 00% 13287 -
#17 Short offline Completed without error 00% 13167 -
#18 Extended offline Completed without error 00% 13151 -
#19 Short offline Completed without error 00% 13047 -
#20 Short offline Completed without error 00% 12927 -
#21 Short offline Completed without error 00% 12832 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.And here's the camcontrol output;
<ATA ST3000DM001-1CH1 CC24> at scbus0 target 0 lun 0 (pass0,da0) <ATA ST3000DM001-9YN1 CC4H> at scbus0 target 1 lun 0 (pass1,da1) <ATA ST3000DM001-1CH1 CC24> at scbus0 target 2 lun 0 (pass2,da2) <ATA ST3000DM001-1CH1 CC24> at scbus0 target 3 lun 0 (pass3,da3) <ATA ST3000DM001-1CH1 CC24> at scbus0 target 4 lun 0 (pass4,da4) <ATA ST3000DM001-1CH1 CC24> at scbus0 target 5 lun 0 (pass5,da5) <ATA ST3000DM001-1CH1 CC24> at scbus0 target 6 lun 0 (pass6,da6) <ATA ST3000DM001-1CH1 CC24> at scbus0 target 7 lun 0 (pass7,da7) <ATA ST3000DM001-1CH1 CC24> at scbus1 target 0 lun 0 (pass8,da8) <ATA ST3000DM001-1CH1 CC24> at scbus1 target 1 lun 0 (pass9,da9) <ATA ST3000DM001-1CH1 CC27> at scbus1 target 3 lun 0 (pass10,da10) <ATA ST3000DM001-1CH1 CC24> at scbus1 target 4 lun 0 (pass11,da11) <ATA ST3000DM001-1CH1 CC24> at scbus1 target 5 lun 0 (pass12,da12) <ATA ST3000DM001-1CH1 CC24> at scbus1 target 7 lun 0 (pass13,da13) <ATA ST3000DM001-1ER1 CC43> at scbus1 target 8 lun 0 (pass14,da14) <ATA WDC WD30EFRX-68E 0A82> at scbus1 target 9 lun 0 (pass15,da15) <ATA ST3000DM001-1CH1 CC24> at scbus2 target 0 lun 0 (pass16,da16) <ATA ST3000DM001-1CH1 CC24> at scbus2 target 1 lun 0 (pass17,da17) <ATA ST3000DM001-1CH1 CC24> at scbus2 target 4 lun 0 (pass18,da18) <ATA ST3000DM001-1CH1 CC24> at scbus2 target 5 lun 0 (pass19,da19) <ATA ST3000DM001-1ER1 CC43> at scbus2 target 7 lun 0 (pass20,da20) <ATA WDC WD30EFRX-68E 0A82> at scbus2 target 8 lun 0 (pass21,da21) <ATA WDC WD30EFRX-68E 0A82> at scbus2 target 9 lun 0 (pass22,da22) <ATA WDC WD30EFRX-68E 0A82> at scbus2 target 10 lun 0 (pass23,da23) <Lexar USB Flash Drive 8.07> at scbus10 target 0 lun 0 (pass24,da24) <Lexar USB Flash Drive 8.07> at scbus11 target 0 lun 0 (pass25,da25)
Device: /dev/da1 [SAT], Temperature 39 Celsius reached critical limit of 39 Celsius (Min/Max 35/39!)
