carlo5369
- Oct 18, 2017
I try to read everywhere before posting but no luck, so I'm asking for help
I' try to join a windows 2003 (...) AD domain with FreeNAS-11.0-U4 (54848d13b)
check ntp --> ok
put freenas in dns --> ok
add computer --> ok
user --> ok
join the domain nothing appends, no row in messages but i found in debug.log
Oct 18 14:15:35 freenasRA uwsgi: [common.warden:437] warden_base.__init__: args = -v
Oct 18 14:15:35 freenasRA uwsgi: [common.warden:443] warden_base.__init__: leave
Oct 18 14:15:35 freenasRA uwsgi: [common.warden:449] warden_base.run: enter
Oct 18 14:15:35 freenasRA uwsgi: [common.warden:458] warden_base.cmd = /usr/local/bin/warden list -v
Oct 18 14:15:35 freenasRA uwsgi: [common.cmd:189] cmd_pipe.__init__: cmd = /usr/local/bin/warden list -v, kwargs = {'pipeopen_kwargs': {}}
Oct 18 14:15:35 freenasRA uwsgi: [common.cmd:219] cmd_pipe.__init__: leave
Oct 18 14:15:35 freenasRA uwsgi: [common.warden:467] warden_base.run: leave
Oct 18 14:15:35 freenasRA uwsgi: [middleware.notifier:198] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }'
Oct 18 14:15:35 freenasRA uwsgi: [middleware.notifier:198] Popen()ing: route -nv show -inet6 default|grep 'interface:'|awk '{ print $2 }'
Oct 18 14:16:18 freenasRA uwsgi: [ws4py:360] Closing message received (1000) 'b'''
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:2441] FreeNAS_ActiveDirectory.__init__: enter
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:1536] FreeNAS_ActiveDirectory_Base.__init__: enter
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:1389] FreeNAS_ActiveDirectory_Base.__set_defaults: enter
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:1425] FreeNAS_ActiveDirectory_Base.__set_defaults: leave
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:1151] FreeNAS_ActiveDirectory_Base.get_SRV_records: looking up SRV records for _ldap._tcp.dc._msdcs.AD_Domain.mcr
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:1151] FreeNAS_ActiveDirectory_Base.get_SRV_records: looking up SRV records for _kerberos._tcp.AD_Domain.mcr
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:1151] FreeNAS_ActiveDirectory_Base.get_SRV_records: looking up SRV records for _kpasswd._tcp.AD_Domain.mcr
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:131] FreeNAS_LDAP_Directory.__init__: enter
Oct 18 14:16:19 freenasRA uwsgi: [common.frenascache:307] FreeNAS_LDAP_QueryCache.__init__: enter
Oct 18 14:16:19 freenasRA uwsgi: [common.frenascache:89] FreeNAS_BaseCache._init__: enter
Oct 18 14:16:19 freenasRA uwsgi: [common.frenascache:110] FreeNAS_BaseCache._init__: cachedir = /var/tmp/.cache/.query
Oct 18 14:16:19 freenasRA uwsgi: [common.frenascache:113] FreeNAS_BaseCache._init__: cachefile = /var/tmp/.cache/.query/.cache.db
Oct 18 14:16:19 freenasRA uwsgi: [common.frenascache:115] FreeNAS_BaseCache._init__: leave
Oct 18 14:16:19 freenasRA uwsgi: [common.frenascache:315] FreeNAS_LDAP_QueryCache.__init__: leave
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:177] FreeNAS_LDAP_Directory.__init__: host = Name_server.AD_Domain.mcr, port = 636, binddn = freenas_user@AD_Domain.mcr, basedn = None, ssl = on
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:179] FreeNAS_LDAP_Directory.__init__: leave
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:277] FreeNAS_LDAP_Directory.open: enter
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:284] FreeNAS_LDAP_Directory.open: uri = ldaps://Name_server.AD_Domain.mcr:636
Oct 18 14:16:19 freenasRA uwsgi: [common.freenasldap:287] FreeNAS_LDAP_Directory.open: initialized
Oct 18 14:16:19 freenasRA uwsgi: [directoryservice.models:1036] ActiveDirectory: Unable to create kerberos realm: <built-in method set_option of LDAP object at 0x81c9854b8> returned a result with an error set
Oct 18 14:16:21 freenasRA uwsgi: [directoryservice.form:690] [ServiceMonitoring] Remove activedirectory service, frequency: 60, retry: 10
Oct 18 14:16:21 freenasRA uwsgi: [ws4py:360] Closing message received (1000) 'b'''
root@freenasRA:~ # wbinfo -t
checking the trust secret for domain AD_DOMAIN via RPC calls failed
wbcCheckTrustCredentials(AD_DOMAIN): error code was NT_STATUS_NO_SUCH_DOMAIN (0xc00000df)
failed to call wbcCheckTrustCredentials: WBC_ERR_AUTH_ERROR
Could not check secret
root@freenasRA:~ #
(I'm sure about password!)
Can somebody help me?
Thank you in advance and feel free to contact me for further information.
Carlo
check ntp --> ok
add computer --> ok
user --> ok
root@freenasRA:~ #
Carlo
