oasisck
- Jan 21, 2018
Hi everyone,
I'm using FreeNAS since 1 year. ATM I'm using 11.1-U5
I want to create a VM but it won't start.
It says "device not configured". I guess it's for the NIC. I look around everywhere but I can't find it.
This is why I call you guys.
root@freenas:~ # tail -f /var/log/messages /var/log/middlewared.log /var/log/debug.log ==> /var/log/messages <== Jun 19 15:49:01 freenas kernel: tap0: promiscuous mode enabled Jun 19 15:52:17 freenas tap0: Ethernet address: 00:bd:57:34:fd:00 Jun 19 15:52:17 freenas kernel: tap0: promiscuous mode enabled Jun 19 15:52:17 freenas rtsold[1401]: <rtsock_input_ifannounce> interface tap0 removed Jun 19 15:54:58 freenas rtsold[1401]: <rtsock_input_ifannounce> interface tap0 removed Jun 19 15:54:59 freenas tap0: Ethernet address: 00:bd:fa:aa:ff:00 Jun 19 15:54:59 freenas kernel: tap0: promiscuous mode enabled Jun 19 17:11:40 freenas tap0: Ethernet address: 00:bd:84:e0:45:00 Jun 19 17:11:40 freenas kernel: tap0: promiscuous mode enabled Jun 19 17:11:40 freenas rtsold[1401]: <rtsock_input_ifannounce> interface tap0 removed ==> /var/log/middlewared.log <== [2018/06/19 13:54:58] (DEBUG) VMService.run():250 - centreon: vm_create: Device not configured [2018/06/19 13:54:58] (INFO) VMService.run():265 - ===> Powered off VM: centreon ID: 3 BHYVE_CODE: 1 [2018/06/19 13:54:58] (WARNING) VMService.destroy_vm():275 - ===> Destroying VM: centreon ID: 3 BHYVE_CODE: 1 [2018/06/19 15:11:40] (DEBUG) VMService.run():155 - ====> NIC_ATTACH: re0 [2018/06/19 15:11:40] (DEBUG) VMService.run():231 - Starting bhyve: bhyve -H -w -c 1 -m 1000 -s 0:0,hostbridge -s 31,lpc -l com1,/dev/nmdm3A -l bootrom,/usr/local/share/uefi-firmware/BHYVE_UEFI.fd -s 29,fbuf,vncserver,tcp=192.168.1.250:5903,w=1920,h=1080,, -s 30,xhci,tablet -s 3,ahci-cd,/mnt/DATA/multimedia/fichiers/ISO/centreon-3.4.6.el7.x86_64.iso -s 4,ahci-hd,/dev/zvol/DATA/VM/centreon -s 5,e1000,tap0,mac=00:a0:98:71:09:69 3_centreon [2018/06/19 15:11:40] (DEBUG) VMService.run():250 - centreon: vm_create: Device not configured [2018/06/19 15:11:40] (INFO) VMService.run():265 - ===> Powered off VM: centreon ID: 3 BHYVE_CODE: 1 [2018/06/19 15:11:40] (WARNING) VMService.destroy_vm():275 - ===> Destroying VM: centreon ID: 3 BHYVE_CODE: 1 ==> /var/log/debug.log <== Jun 19 17:11:46 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = type: standard Jun 19 17:11:46 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = flags: allow.raw_sockets=true Jun 19 17:11:46 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:11:46 freenas uwsgi: [common.cmd:219] cmd_pipe.__init__: leave Jun 19 17:11:46 freenas uwsgi: [common.warden:467] warden_base.run: leave Jun 19 17:11:46 freenas uwsgi: [middleware.notifier:185] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }' Jun 19 17:11:46 freenas uwsgi: [middleware.notifier:185] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }' Jun 19 17:11:46 freenas uwsgi: [middleware.notifier:185] Popen()ing: ifconfig 're0' Jun 19 17:11:47 freenas uwsgi: [freeadmin.navtree:593] Plugin transmission requested to be appended to plugins Jun 19 17:11:48 freenas /alert.py: [ws4py:360] Closing message received (1000) 'b''' ==> /var/log/middlewared.log <== [2018/06/19 15:13:04] (DEBUG) VMService.run():155 - ====> NIC_ATTACH: re0 [2018/06/19 15:13:04] (DEBUG) VMService.run():231 - Starting bhyve: bhyve -H -w -c 1 -m 1000 -s 0:0,hostbridge -s 31,lpc -l com1,/dev/nmdm3A -l bootrom,/usr/local/share/uefi-firmware/BHYVE_UEFI.fd -s 29,fbuf,vncserver,tcp=192.168.1.250:5903,w=1920,h=1080,, -s 30,xhci,tablet -s 3,ahci-cd,/mnt/DATA/multimedia/fichiers/ISO/centreon-3.4.6.el7.x86_64.iso -s 4,ahci-hd,/dev/zvol/DATA/VM/centreon -s 5,e1000,tap0,mac=00:a0:98:2c:de:88 3_centreon [2018/06/19 15:13:04] (DEBUG) VMService.run():250 - centreon: vm_create: Device not configured [2018/06/19 15:13:04] (INFO) VMService.run():265 - ===> Powered off VM: centreon ID: 3 BHYVE_CODE: 1 [2018/06/19 15:13:04] (WARNING) VMService.destroy_vm():275 - ===> Destroying VM: centreon ID: 3 BHYVE_CODE: 1 ==> /var/log/messages <== Jun 19 17:13:04 freenas rtsold[1401]: <rtsock_input_ifannounce> interface tap0 removed Jun 19 17:13:04 freenas tap0: Ethernet address: 00:bd:74:2a:47:00 Jun 19 17:13:04 freenas kernel: tap0: promiscuous mode enabled ==> /var/log/debug.log <== Jun 19 17:13:05 freenas uwsgi: [freeadmin.navtree:114] Unable to import 'freenasUI.api' 'nav': No module named 'freenasUI.api.nav' Jun 19 17:13:05 freenas uwsgi: [freeadmin.navtree:402] App freenasUI.api has no nav.py module, skipping Jun 19 17:13:05 freenas uwsgi: [freeadmin.navtree:114] Unable to import 'freenasUI.freeadmin' 'nav': No module named 'freenasUI.freeadmin.nav' Jun 19 17:13:05 freenas uwsgi: [freeadmin.navtree:402] App freenasUI.freeadmin has no nav.py module, skipping Jun 19 17:13:05 freenas uwsgi: [freeadmin.navtree:114] Unable to import 'freenasUI.documentation' 'nav': No module named 'freenasUI.documentation.nav' Jun 19 17:13:05 freenas uwsgi: [freeadmin.navtree:402] App freenasUI.documentation has no nav.py module, skipping Jun 19 17:13:05 freenas uwsgi: [middleware.notifier:185] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }' Jun 19 17:13:05 freenas uwsgi: [middleware.notifier:185] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }' Jun 19 17:13:05 freenas uwsgi: [middleware.notifier:185] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }' Jun 19 17:13:05 freenas uwsgi: [middleware.notifier:185] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }' Jun 19 17:13:05 freenas uwsgi: [common.warden:406] warden_base.__init__: cmd = list - flags = 0x00000001 Jun 19 17:13:05 freenas uwsgi: [common.warden:437] warden_base.__init__: args = -v Jun 19 17:13:05 freenas uwsgi: [common.warden:443] warden_base.__init__: leave Jun 19 17:13:05 freenas uwsgi: [common.warden:449] warden_base.run: enter Jun 19 17:13:05 freenas uwsgi: [common.warden:458] warden_base.cmd = /usr/local/bin/warden list -v Jun 19 17:13:05 freenas uwsgi: [common.cmd:189] cmd_pipe.__init__: cmd = /usr/local/bin/warden list -v, kwargs = {'pipeopen_kwargs': {}} Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = id: 14 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = host: dhcpd Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = iface: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv4: 192.168.1.209/24 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv4: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv4: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv4: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv4: 192.168.1.1 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv6: AUTOCONF Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv6: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv6: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv6: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv6: AUTOCONF Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = autostart: Enabled Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = vnet: Enabled Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = nat: Disabled Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = mac: aa:ce:d7:c4:54:27 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = status: Running Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = type: standard Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = flags: allow.raw_sockets=true Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = id: 8 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = host: transmission_1 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = iface: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv4: 192.168.1.207/24 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv4: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv4: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv4: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv4: 192.168.1.1 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv6: AUTOCONF Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv6: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv6: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv6: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv6: AUTOCONF Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = autostart: Enabled Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = vnet: Enabled Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = nat: Disabled Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = mac: 5e:98:e3:39:72:03 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = status: Running Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = type: pluginjail Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = flags: allow.raw_sockets=true Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = id: 13 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = host: unbound Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = iface: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv4: 192.168.1.204/24 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv4: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv4: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv4: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv4: 192.168.1.1 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv6: AUTOCONF Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv6: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv6: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv6: Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv6: AUTOCONF Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = autostart: Enabled Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = vnet: Enabled Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = nat: Disabled Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = mac: be:bc:34:75:04:79 Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = status: Running Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = type: standard Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = flags: allow.raw_sockets=true Jun 19 17:13:06 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:06 freenas uwsgi: [common.cmd:219] cmd_pipe.__init__: leave Jun 19 17:13:06 freenas uwsgi: [common.warden:467] warden_base.run: leave Jun 19 17:13:06 freenas uwsgi: [middleware.notifier:185] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }' Jun 19 17:13:14 freenas /alert.py: [ws4py:360] Closing message received (1000) 'b''' Jun 19 17:13:14 freenas uwsgi: [services.forms:1167] Failed to decrypt DDNS password Traceback (most recent call last): File "./freenasUI/services/models.py", line 1165, in _decrypt_password self.ddns_password = notifier().pwenc_decrypt(self.ddns_password) File "./freenasUI/middleware/notifier.py", line 3862, in pwenc_decrypt encrypted = base64.b64decode(encrypted) File "/usr/local/lib/python3.6/base64.py", line 87, in b64decode return binascii.a2b_base64(s) binascii.Error: Incorrect padding Jun 19 17:13:14 freenas uwsgi: [freeadmin.navtree:114] Unable to import 'freenasUI.support' 'nav': No module named 'freenasUI.support.nav' Jun 19 17:13:14 freenas uwsgi: [freeadmin.navtree:402] App freenasUI.support has no nav.py module, skipping Jun 19 17:13:14 freenas uwsgi: [common.warden:406] warden_base.__init__: cmd = list - flags = 0x00000001 Jun 19 17:13:14 freenas uwsgi: [common.warden:437] warden_base.__init__: args = -v Jun 19 17:13:14 freenas uwsgi: [common.warden:443] warden_base.__init__: leave Jun 19 17:13:14 freenas uwsgi: [common.warden:449] warden_base.run: enter Jun 19 17:13:14 freenas uwsgi: [common.warden:458] warden_base.cmd = /usr/local/bin/warden list -v Jun 19 17:13:14 freenas uwsgi: [common.cmd:189] cmd_pipe.__init__: cmd = /usr/local/bin/warden list -v, kwargs = {'pipeopen_kwargs': {}} Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = id: 14 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = host: dhcpd Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = iface: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv4: 192.168.1.209/24 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv4: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv4: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv4: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv4: 192.168.1.1 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv6: AUTOCONF Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv6: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv6: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv6: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv6: AUTOCONF Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = autostart: Enabled Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = vnet: Enabled Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = nat: Disabled Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = mac: aa:ce:d7:c4:54:27 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = status: Running Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = type: standard Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = flags: allow.raw_sockets=true Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = id: 8 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = host: transmission_1 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = iface: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv4: 192.168.1.207/24 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv4: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv4: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv4: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv4: 192.168.1.1 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv6: AUTOCONF Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv6: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv6: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv6: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv6: AUTOCONF Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = autostart: Enabled Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = vnet: Enabled Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = nat: Disabled Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = mac: 5e:98:e3:39:72:03 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = status: Running Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = type: pluginjail Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = flags: allow.raw_sockets=true Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = id: 13 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = host: unbound Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = iface: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv4: 192.168.1.204/24 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv4: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv4: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv4: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv4: 192.168.1.1 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = ipv6: AUTOCONF Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-ipv6: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = bridge-ipv6: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = alias-bridge-ipv6: Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = defaultrouter-ipv6: AUTOCONF Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = autostart: Enabled Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = vnet: Enabled Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = nat: Disabled Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = mac: be:bc:34:75:04:79 Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = status: Running Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = type: standard Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = flags: allow.raw_sockets=true Jun 19 17:13:15 freenas uwsgi: [common.cmd:208] cmd_pipe.__init__: out = Jun 19 17:13:15 freenas uwsgi: [common.cmd:219] cmd_pipe.__init__: leave Jun 19 17:13:15 freenas uwsgi: [common.warden:467] warden_base.run: leave Jun 19 17:13:15 freenas uwsgi: [middleware.notifier:185] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }' Jun 19 17:13:15 freenas uwsgi: [middleware.notifier:185] Popen()ing: route -nv show default|grep 'interface:'|awk '{ print $2 }' Jun 19 17:13:15 freenas uwsgi: [middleware.notifier:185] Popen()ing: ifconfig 're0' Jun 19 17:13:15 freenas uwsgi: [freeadmin.navtree:593] Plugin transmission requested to be appended to plugins
