A
Athanasios Kakargias
Guest
I was trying to install serviio v0.6 on FreeNAS 8.0.1 RC-2 using http://forums.freenas.org/showthread.php?1399-HOWTO-Install-Serviio-in-Freenas-8.0.1Beta4
So I
I had the following error after I installed diablo latte
Seems there is some library ?bump? according to freebsd mailing list on jdk16
and apparently it works for jre too so you need
if you are running from usb like me you need also
So I
mount -urw / pkg_add -v -r xtrans pkg_add -v -r xproto pkg_add -v -r xextproto pkg_add -v -r javavmwrapper pkg_add -v -r ffmpeg pkg_add -v ~/diablo-jre-freebsd7.amd64.1.6.0.07.02
Error occurred during initialization of VM Unable to load ZIP library: /usr/local/diablo-jre1.6.0/lib/amd64/libzip.so
echo libz.so.4 libz.so.5 > /etc/libmap.conf
cp /etc/local/javavm* /conf/base/etc/local/ echo libz.so.4 libz.so.5 > /conf/base/etc/libmap.conf
