Jails: VIMAGE option unavailable (greyed)
shpokas
Hi there,
any idea why VIMAGE option is unavailable in my FreeNAS installation?
I have another test installation and all is fine there.
But this one was migrated and upgraded from 32-bit to 64-bit.
Note, promiscuous mode is enabled on interface (according to manual) even it seems not to be required for my test installation.
[root@vfs] ~# ifconfig bridge0
bridge0: flags=28943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST,PPROMISC> metric 0 mtu 1500
ether 02:c0:75:36:94:00
inet 192.168.X.X netmask 0xffffff00 broadcast 192.168.17.255
nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000000
member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 20000
Cheers,
shpokas
shpokas
Answering myself :/
Quite accidentally I found that all jail templates are listed as x86, 32-bit that is.
As soon as I changed them to 64-bit, VIMAGE option became available.
