gmhafiz
- Nov 22, 2021
Last week my syncthing jail began to fail. Its UI at port 8080 was showing the default nginx page. Inaccessible.
Today, the syncthing UI is totally inaccessible. On top of that my plex jail failed too, getting a connection refused
I can confirm all my files are still present by accessing by sftp.
When trying to access the Jail menu, I get OSError [Errno 6] Device not configured
In alert, I get
/var/db/system/update gas some files in it
curl -vv http://192.168.1.106:8080/ * Trying 192.168.1.106:8080... * TCP_NODELAY set * connect to 192.168.1.106 port 8080 failed: Connection refused * Failed to connect to 192.168.1.106 port 8080: Connection refused * Closing connection 0 curl: (7) Failed to connect to 192.168.1.106 port 8080: Connection refused
curl -vv http://192.168.1.104:32400/web/index.html * Trying 192.168.1.104:32400... * TCP_NODELAY set * connect to 192.168.1.104 port 32400 failed: Connection refused * Failed to connect to 192.168.1.104 port 32400: Connection refused * Closing connection 0 curl: (7) Failed to connect to 192.168.1.104 port 32400: Connection refused
Error: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 1266, in check_default_config default_props = json.load(default_json) File "/usr/local/lib/python3.9/json/__init__.py", line 293, in load return loads(fp.read(), OSError: [Errno 6] Device not configured During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 137, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self, File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1209, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1113, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 977, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/jail_freebsd.py", line 1054, in get_activated_pool pool = ioc.IOCage(skip_jails=True, reset_cache=True).get('', pool=True) File "/usr/local/lib/python3.9/site-packages/iocage_lib/iocage.py", line 95, in __init__ self.generic_iocjson = ioc_json.IOCJson() File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 1372, in __init__ super().__init__(location, checking_datasets, silent, callback) File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 432, in __init__ self.default_config = self.check_default_config() File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 1301, in check_default_config self.backup_iocage_jail_conf(default_json_location) File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 919, in backup_iocage_jail_conf shutil.copy( File "/usr/local/lib/python3.9/shutil.py", line 418, in copy copyfile(src, dst, follow_symlinks=follow_symlinks) File "/usr/local/lib/python3.9/shutil.py", line 285, in copyfile copyfileobj(fsrc, fdst) File "/usr/local/lib/python3.9/shutil.py", line 205, in copyfileobj buf = fsrc_read(length) OSError: [Errno 6] Device not configured
In alert, I get
Failed to check for alert HasUpdate: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/alert.py", line 740, in __run_source alerts = (await alert_source.check()) or [] File "/usr/local/lib/python3.9/site-packages/middlewared/alert/base.py", line 210, in check return await self.middleware.run_in_thread(self.check_sync) File "/usr/local/lib/python3.9/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/site-packages/middlewared/utils /io_thread_pool_executor.py", line 25, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/alert/source/update.py", line 67, in check_sync path = self.middleware.call_sync("update.get_update_location") File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1257, in call_sync return self.run_coroutine(methodobj(*prepared_call.args)) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1297, in run_coroutine return fut.result() File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 438, in result return self.__get_result() File "/usr/local/lib/python3.9/concurrent/futures /_base.py", line 390, in __get_result raise self._exception File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/update.py", line 412, in get_update_location os.chmod(path, 0o755) OSError: [Errno 6] Device not configured: '/var/db/system/update'
