Hello Guys
I have weird problem that i shutdown my truenas couple of days ago and since then I'm facing strange issues randomly :
1. VMs are hanged and not able to shutdown after minutes of boot.
2. Mulyy jails errors and hanging after minutes of boot too.
This is one of the error I'm facing when press jails tab :
File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 1266, in check_default_config
default_props = json.load(default_json)
File "/usr/local/lib/python3.9/json/__init__.py", line 293, in load
return loads(fp.read(),
OSError: [Errno 6] Device not configured
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 138, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1216, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1120, in run_in_executor
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 977, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/jail_freebsd.py", line 1054, in get_activated_pool
pool = ioc.IOCage(skip_jails=True, reset_cache=True).get('', pool=True)
File "/usr/local/lib/python3.9/site-packages/iocage_lib/iocage.py", line 95, in __init__
self.generic_iocjson = ioc_json.IOCJson()
File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 1372, in __init__
super().__init__(location, checking_datasets, silent, callback)
File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 432, in __init__
self.default_config = self.check_default_config()
File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 1301, in check_default_config
self.backup_iocage_jail_conf(default_json_location)
File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_json.py", line 919, in backup_iocage_jail_conf
shutil.copy(
File "/usr/local/lib/python3.9/shutil.py", line 418, in copy
copyfile(src, dst, follow_symlinks=follow_symlinks)
File "/usr/local/lib/python3.9/shutil.py", line 264, in copyfile
with open(src, 'rb') as fsrc, open(dst, 'wb') as fdst:
OSError: [Errno 6] Device not configured: '/mnt/JailsCloudSSD/iocage/defaults_backup.json'
Note...the system is working fine after reboot but in few minutes later everything start hanging and failing..!!!
Hope i can find a fix for that...
Thanks
shutil.copy(
Thanks
