[EFAULT] Failed to set NT password for XXX: Username not found! (smb.synchronize_passdb)
YuriiV
Hello, cant create new user smb, its created in system without problem, but when start smb.synchronize_passdb process I have error
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/smb_/passdb.py", line 194, in synchronize_passdb
await self.middleware.call('smb.update_passdb_user', u['username'], passdb_backend)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1256, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1213, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/smb_/passdb.py", line 112, in update_passdb_user
raise CallError(f'Failed to set NT password for {username}: {setntpass.stderr.decode()}')
middlewared.service_exception.CallError: [EFAULT] Failed to set NT password for XXX: Username not found!
anodos
Sambassador
Okay. This was an issue in how RID values were generated. Will be fixed in 13 release (and is fixed in SCALE). Simple workaround if you get in this state:
rm /var/db/system/samba4/private/passdb.tdb
midclt call smb.synchronize_passdb -job
YuriiV
Thanks, it helped, the only thing to correctly re-create the file, I had to disable the SMB service
ncmarc
I have this same issue happening. Is this still the best way to handle it. Is there something we can do to avoid it when adding users?
anodos
Sambassador
If you're experiencing the issue you can fix it that way. 12.0-stable branch is basically security fixes only. 13-stable should have the issue addressed.
