I recently upgraded to TrueNAS 12.2 and it went fine. Today, I backed up some files as I usually do: import an external drive, copy the files over, and then disconnect the drive. But today, I got this error:
What could this be? The complete traceback is this:
The back up completed just fine but I don't want to simply unplug the drive since I'm afraid it can become corrupted. Some advice please?
Error: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run await self.future File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1572, in export await self.middleware.call('disk.swaps_remove_disks', disks, {'configure_swap': False}) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1256, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1213, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 42, in l_fn return await fn(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk_/swap_remove.py", line 27, in swaps_remove_disks return await self.swaps_remove_disks_unlocked(disks, options) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk_/swap_remove.py", line 54, in swaps_remove_disks_unlocked await run('swapoff', devname) File "/usr/local/lib/python3.9/site-packages/middlewared/utils/__init__.py", line 62, in run cp.check_returncode() File "/usr/local/lib/python3.9/subprocess.py", line 460, in check_returncode raise CalledProcessError(self.returncode, self.args, self.stdout, subprocess.CalledProcessError: Command '('swapoff', '/dev/mirror/swap0.eli')' returned non-zero exit status 1. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 371, in run raise handled middlewared.service_exception.CallError: [EFAULT] Command swapoff /dev/mirror/swap0.eli failed (code 1): swapoff: /dev/mirror/swap0.eli: Cannot allocate memory
