rmccullough
- May 17, 2018
I have 4 x GBe ports on my server. I am currently only using one port that is configured via DHCP w/ a static IP from my pfSense router. What I would like to know is if there would be performance advantages to activating additional NIC ports and use them for jails? Whereas the current port would remain for system services and shares and such.
I went to go configure a 2nd port, but it threw an error saying Only one interface can be used for DHCP.
I suppose I could configure this w/ a static IP in TrueNAS, but it would be nice to just have it use DHCP and pull a static IP from my DHCP server.
Am I overthinking this? Is this not worth messing with trying to add a separate NIC to segregate the traffic? It would be plugged into a 24 port GBe switch. It's not a high-end one, just a cheapy TendNET "Green" one. If I were to upgrade the switch, would this then become more worthwhile? I have been kicking around adding a switch that has SFP+ cages and looking at adding fiber or 10GBe between my crawlspace (where router and TrueNAS is) and my office.
