quantumnerd
- May 26, 2013
I installed FreeNAS 9.1.0-RELEASE and set up a jail in which I installed Deluge and mounted my home directory (/mnt/wdpool/matt) to the jail's /mnt . Everything seemed to work fine, until I tried downloading, and noticed that even though the file showed up inside the jail under /mnt/torrents, it didn't show up inside /mnt/wdpool/matt/torrents . I investigated further. Even though the initial mount had made everything in my home directory visible to the jail, changes in most places below the root of my home directory didn't seem to sync across. But changes made inside the .ssh folder would.
Basically: any changes made inside my mounted home dir's torrent dataset don't sync. But any changes made inside my mounted home dir's .ssh folder do.
The simple workaround for this is for me to structure my data so that every dataset I want to torrent into is mounted separately. As long as they don't have datasets underneath, there won't be problems. But is this broken behavior?
