Jails are not starting after reboot
veryaner
Hello, I have TrueNAS-12.0-RELEASE installed for a few weeks and yesterday I have to restart it, after that none of my jails started, I try from the web and also from the shell and the only message that I got is this:
From the web the spinner stays forever.
My /var/log/messages doesn't says anything and netiher the iocage.log
Thanks!
What about dmesg ?
Jailer
Not strong, but bad
Disable ipv6 in the jails network settings and try starting it again.
arp: 192.168.1.1 moved from b0:be:76:e9:c0:c7 to 14:4d:67:00:b7:c4 on em0
Seems like 2 boxes are fighting for ownership of the router's address on your network... can be that it's a microtik with a known bug there (no need for concern in that case)
Can you see from your router which clients have those MAC addresses?
What do you see from iocage get all <jailname> | grep ip6
I think you want to be seeing:
ip6:disable
ip6_addr:none
ip6_saddrsel:1
You could use:
iocage set ip6=disable <jailname> to change it
veryaner
I cannot find them in my DHCP list,
ip6:disable
ip6_addr:none
ip6_saddrsel:1
You could use:
Same Behavior after that set.
How about the rest of your jail parameters...
iocage get all <jailname> | more
Bonoboy
This is what solved it at my system.
edit jail
Basic Properties:
IPv6 Default Router from auto to none
Jail Properties:
devfs_ruleset from nr* to 4
Network Properties:
ip6 New to Disable
Although i don't know if it's a problem when devfs_ruleset 4 is set on all jails.
