jails and plugin screen does not load
freenas4n00b
I have a new 9.2-RELEASE install. After creating the volumes and datasets, the rest of the tabs was unable to load. When i click on jails, plugins, or system information, i get a very generic error "Sorry, an error occurred".
What logs can i look at to determine what is wrong?
freenas4n00b
more information, didnt realize the problem is bigger than just a UI issue. The box was unpingable. You would expect the browser to return 404 if that was the case but it didnt.
Somehow the box lost its IPs and will not get it back. I tried running /etc/netstart and it doesnt work. When i try to ping google / other hosts i get arprequest: cannot find matching address.
freenas4n00b
hmmm i unplugged one of my nic interfaces, went to console and reset to factory settings and it works now after restart and auto import zfs volumes.
freenas4n00b
This is solved. I do not know why my initial configuration got screwed up with dual NICs but everything was fine after i unplugged one of the NICs and reset to factory settings
