i have delit all. hmm..
i do all one more time.
Make sure to reboot after they are all deleted.
ok now i have deleted all .warden*
after that i go in i gui and reboot freenas.
when it back up i try to install a plugin agen.
and i got this
Feb 18 22:20:07 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: Abort trap ERROR: Failed extracting: http://cdn.freenas.org/9.2.0/RELEASE/x64/jails/freenas-pluginjail-9.2-RELEASE.tgz cannot open 'raid-z1/jail/.warden-template-pluginjail': dataset does not exist ERROR: Failed to create ZFS base dataset ]
I dont have any .warden folders in jail anymore.
do i not need to create this ? storage/jails/.warden-template-pluginjail
You shouldn't have to create that. It's automatically done. For some reason it is failing. Post the output of 'sudo zfs list'
same like befor
NAME USED AVAIL REFER MOUNTPOINT
raid-z1 4.08T 6.63T 2.36T /mnt/raid-z1
raid-z1/.samba4 2.94M 6.63T 2.94M /mnt/raid-z1/.samba4
raid-z1/archive 1.73T 6.63T 1.70T /mnt/raid-z1/archive
raid-z1/archive/Privet 23.6G 6.63T 23.6G /mnt/raid-z1/archive/Privet
raid-z1/home 716K 6.63T 256K /mnt/raid-z1/home
raid-z1/home/guest 230K 6.63T 230K /mnt/raid-z1/home/guest
raid-z1/home/mullcom 230K 6.63T 230K /mnt/raid-z1/home/mullcom
raid-z1/jail 13.4M 6.63T 13.4M /mnt/raid-z1/jail
raid-z1/opt 249K 6.63T 249K /mnt/raid-z1/opt
raid-z1/security 2.53M 6.63T 2.53M /mnt/raid-z1/security
Ok, that looks fine. I don't understand why it's failing to create the dataset. Let's try to do it manually and see what happens. Run this from a shell: 'sudo zfs create raid-z1/jail/.warden-template-pluginjail' and post the error if there is any.
no error att all.
checking and i got .warden-template-pluginjail folder now.
No error means it succeeded. You could try installing a plugin and see what happens. I'm not sure if the gui will get confused because the dataset was manually created.
ok..
then i get this....
Feb 18 23:07:21 freenas manage.py: [py.warnings:613] /usr/local/www/freenasUI/../freenasUI/jails/utils.py:613: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6 raise MiddlewareError(e.message)
Feb 18 23:07:21 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: ERROR: A template with this nickname already exists! ]
I kind of figured that would happen. Delete the dataset we manually created with 'zfs destroy raid-z1/jail/.warden-template-pluginjail' then reboot. ry the plugin install again. If it still fails then I don't know what else to try. If you don't have any other jails or plugins installed you could try removing the jail dataset from the storage tab in the gui then reboot then try to install plugins again.
ok thx alot for the help.. hope thay fix this soon.
sudo zpool export raid-z1 sudo zpool import raid-z1 raidz1 sudo zpool export
I have an idea what may be the issue. I wonder if the - in your pool name "raid-z1" is causing issues? You could try and rename your pool.
Renaming a zpool is quite simple to do. Make sure to stop any sharing services and jails before you do this. All you do is the following in a shell:
Code:sudo zpool export raid-z1 sudo zpool import raid-z1 raidz1 sudo zpool export
Then in the gui go to the storage tab and use auto import to import the newly named zvol. I would reboot after that. After you reboot you may have an old entry in the storage tab for your old zpool. You should be able to remove that. You will also have to update any shares and jail configuration to use the new zpool name.
EDIT: Here is a better guide on renaming zpools in freenas. http://blogs.itramblings.com/post/2013/07/05/How-to-rename-a-ZFS-Volume-on-FreeNas.aspx I'm half asleep here so my directions are probably off.
How did you get 2 mnt folders? That shouldn't be.
solfrid 6.26G 210G 152K /mnt/solfrid solfrid/jails 6.25G 210G 272K /mnt/solfrid/jails solfrid/jails/.warden-template-pluginjail-9.2-RELEASE-x64 702M 210G 702M /mnt/mnt/solfrid/jails/.warden-template-pluginjail-9.2-RELEASE-x64 solfrid/jails/plexmediaserver_1 5.56G 210G 6.24G /mnt/solfrid/jails/plexmediaserver_1
You may have to manually rename your .warden-template-pluginjail dataset. I had to do that.
Do a zfs list from a shell. If you see .warden-template-pluginjail with some version numbers on it then it needs to be renamed. It should be just ".warden-template-pluginjail"
Rename it by doing:
zfs rename oldname newname
EX: zfs rename storage/jails/.warden-template-pluginjail9.2-blahblahblah-X64 storage/jails/.warden-template-pluginjail
Then reset the mountpoint (mine got destroyed)
zfs inherit mountpoint storage/jails/.warden-template-pluginjail
Tank01/jails/.warden-template-pluginjail 594M 973G 594M none Tank01/jails/.warden-template-pluginjail--x64 903M 973G 896M none
Tank01/jails/.warden-template-pluginjail 594M 961G 594M /mnt/Tank01/jails/.warden-template-pluginjail Tank01/jails/.warden-template-pluginjail--x64 903M 961G 896M /mnt/Tank01/jails/.warden-template-pluginjail--x64
