You may have to manually rename your .warden-template-pluginjail dataset. I had to do that.
Do a zfs list from a shell. If you see .warden-template-pluginjail with some version numbers on it then it needs to be renamed. It should be just ".warden-template-pluginjail"
Rename it by doing:
zfs rename oldname newname
EX: zfs rename storage/jails/.warden-template-pluginjail9.2-blahblahblah-X64 storage/jails/.warden-template-pluginjail
Then reset the mountpoint (mine got destroyed)
zfs inherit mountpoint storage/jails/.warden-template-pluginjail
Hi..
ok i going to check more deep on this then..
i found out this....
---[1]-----------------------------------------------------------------------------------------------
./ ../ .warden-template-pluginjail-9.2-RELEASE-x64/
[zzz@xxx] /mnt/mnt/raid-z1/jails%
----[2]---------------------------------------------------------------------------------------------
./ ../ .plugins/ .warden-files-cache/
[zzz@xxx] /mnt/raid-z1/jail%
I think the first one should not be there anymore?
