Hi Folks
I was TrueNAS 12.1. I had setup a plugin transmission. This created a jail and Transmission was installed in it. Then i manually created another jail called grafana to install grafana/influxdb. I configure the same it was working fine. I was able to setup a sample dashboard also
Then i upgraded to TrueNAS 12.2. The transmission jail works fine. But the garfana jail will not come up. If i click start in the GUI, for a fraction of a second the status changes to up and then becomes down.
I then tried to start the jail manually from the command line. First command i tried and the error i got is shown below:
So then as per the error i tried this
I looked at the config.json file in the jail directory and could find it there with hostname etc
So any ideas on what could be the issue. While i dont mind setting up the jail again since i am just starting out, but would like to know what the issue was and how to avoid it going forward.
prompt># service jail start garfana
Cannot 'start' jail. Set jail_enable to YES in /etc/rc.conf or use 'onestart' instead of 'start'.
prompt># service jail onestart garfana
Starting jails:/etc/rc.d/jail: WARNING: Invalid configuration for garfana  (no jail.conf, no hostname, or no path).   Jail garfana was ignored.
