I have a single jail on a 8.3.1-RELEASE-p2-x64 system. To reconfigure my network for a new router, I had to change the jail's netmask from /24 to /16 (didn't change the IP). I stopped the Plugins service, changed the netmask and tried to start the Plugins service back. It wouldn't start, so I rebooted. After that, the jail id was 3 (it had always been 1 earlier).
I guess because of this, the plugins don't appear in the left side treeview of freenas gui anymore, even though they are running and I can access their gui at the jail's IP address. Also, they all appear "Off" under Services -> Plugins section. I also see this in the console log (jail ip: 192.168.1.250, freenas host ip: 192.168.1.144):
Correspondingly, in nginx-error.log:
I tried adding a gateway for the jail in the gui amd specified the WebGUI Address explicitly. It didn't seem to help, and after rebooting again, the jail id became 6!
Both the freenas host and the jail are ping'able from each other. There is nothing else trying to use the jail's IP. I can access the internet from the jail, and the volumes mounted inside the jail are also available. It seems all the software inside the jail is running fine, but
1. The WebGUI is not able to contact/manage those software
2. The jail id changes on reboot
I have searched this forum and some folks have experienced similar issues, but I didn't see anything that can help me fix my problem (other than rebooting). Any advice? I can dig in more if I get some pointers as to where/what to look at.
Thanks,
Saurav.
ifconfig -a on the freenas host
ifconfig -a in the jail
Jul 15 13:22:20 freenas manage.py: [freeadmin.navtree:416] Couldn't retrieve http://192.168.1.144/plugins/minidlna/_s/treemenu: HTTP Error 502: Bad Gateway
2013/07/15 13:22:20 [error] 68128#0: *4222 kevent() reported about an closed connection (61: Connection refused) while reading response header from upstream, client: 192.168.1.144, server: localhost, request: "GET /plugins/minidlna/_s/treemenu HTTP/1.1", upstream: "fastcgi://192.168.1.250:12346", host: "192.168.1.144"
Thanks,
Saurav.
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
ether 68:b5:99:72:b6:5f
inet 192.168.1.144 netmask 0xffff0000 broadcast 192.168.255.255
media: Ethernet autoselect (1000baseT <full-duplex,flowcontrol,rxpause,txpause>)
status: active
options=3<RXCSUM,TXCSUM>
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x8
inet6 ::1 prefixlen 128
nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
ether 02:5e:ee:2d:95:00
maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200
member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:a5:07:00:0a:0a
status: active
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:a5:07:00:0b:0b
inet 192.168.1.250 netmask 0xffff0000 broadcast 192.168.255.255
inet6 fe80::a5:7ff:fe00:b0b%epair0b prefixlen 64 scopeid 0x2
status: active
