Jail hangs - Repository FreeBSD has a wrong packagesite
Bostjan
I was adding a jail in FreeNAS web UI. With Add Jail button I added a jail. For the first time it took a little time to finish. Then I opened shell from FreeNAS web UI. First I changed root password with # passwd then I wanted to update the jail
# pkg upgrade
then I've got an error
Updating FreeBSD repository catalogue...
pkg: Repository FreeBSD has a wrong packagesite, need to re-create database
The jail/shell hanged. I suppose. Well it didn't do anything. I was waiting for about an hour.
When I was making a jail I tried with VIMAGE option and without. In Template option there is just VirtualBox option or no option.
I already have some Plugin jails created and they all work.
What did I do wrong?
D
dlavigne
Guest
Were you able to resolve this error? If not, does adding a default gateway to that screen fix it? Is a DHCP server available in your network? If so, does switching to DHCP fix it?
Bostjan
I have deleted my manualy created jails once more and I've created them once more.
Now this works
# pkg upgrade
And I've tested and also this works.
# pkg install owncloud
Slacker ITADM
Glad it worked for you but I am having a similar problem.
FreeNAS-9.10-STABLE-201603252134 (412fb1c)
[OwnCloud] Fetching meta.txz: 100% 968 B 1.0kB/s 00:01
[OwnCloud] Fetching packagesite.txz: 100% 5 MiB 557.6kB/s 00:10
Processing entries: 0%
pkg: wrong architecture: freebsd:9:x86:64 instead of FreeBSD:10:amd64
pkg: repository FreeBSD contains packages with wrong ABI: freebsd:9:x86:64
Processing entries: 100%
Unable to update repository FreeBSD
All repositories are up-to-date.
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
root@OwnCloud:/ # pkg install nano
pkg: http://pkg.FreeBSD.org/freebsd:9:x86:64/latest/meta.txz: No address record
repository FreeBSD has no meta file, using default settings
pkg: http://pkg.FreeBSD.org/freebsd:9:x86:64/latest/packagesite.txz: No address
record
pkg: No packages available to install matching 'nano' have been found in the rep
ositories
root@OwnCloud:/ #
Slacker ITADM
I can ping the ip of my jail, 192.168.1.31
I ping google.com and 8.8.8.8 from within the jail.
dig google.com returns:
root@OwnCloud:/ # dig google.com
dig: Command not found.
root@OwnCloud:/ #
Jail is set to DHCP
Freenas Network settings are as follows:
Name IPv4 Address IPv6 Address
igb0 192.168.1.12/24
192.168.1.31/24
igb1 192.168.1.14/24
Nameserver
8.8.8.8
8.8.4.4
Default route
192.168.1.1
