Hey guys,
I fear i'm on borrowed time as I have no system dataset currently. After reading 2 different forum posts about moving the system dataset I decided it was time. I used the Web GUI to select a new Volume for the system dataset. To my amazement I watched it not create the new one and delete the source one using zfs list. I feel like it should leave a copy and a few more checks and balances before it deletes but that is not the current topic (Might be a bug while running domain joined since samba doesn't like to restart while AD is enabled). The GUI doesn't load the system dataset page any more so I can't fix this from the GUI. It also appears smb is running but not serving. I still can see my data on disk at least. Looks like the log files were a link to the system dataset. Not sure where to start on missing system dataset.
EDIT
Here was the error message I had on the dataset page. After a few minutes the page loads but i'm not going to touch it since I don't see a system dataset in zfs list still.
lrwxr-xr-x 1 root wheel 58 Jan 1 23:44 log -> /var/db/system/syslog-76c11d7f8a944b3d8e42fe35420dbaa3/log
EDIT
Request Method: POST Request URL: http://nas.domain.com/admin/system/systemdataset/edit/1/?inline=true Software Version: FreeNAS-11.1-RELEASE (dc7d195f4) Exception Type: ClientException Exception Value: [Errno 66] Directory not empty: '/tmp/system.new' Exception Location: /usr/local/lib/python3.6/site-packages/middlewared/client/client.py in call, line 394 Server time: Wed, 3 Jan 2018 09:46:11 -0600 Traceback Environment: Software Version: FreeNAS-11.1-RELEASE (dc7d195f4) Request Method: POST Request URL: http://nas.domain.com/admin/system/systemdataset/edit/1/?inline=true Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 42. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/freeadmin/options.py" in wrapper 210. return self._admin.admin_view(view)(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/django/utils/decorators.py" in _wrapped_view 149. response = view_func(request, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/django/views/decorators/cache.py" in _wrapped_view_func 57. response = view_func(request, *args, **kwargs) File "./freenasUI/freeadmin/site.py" in inner 142. return view(request, *args, **kwargs) File "./freenasUI/freeadmin/options.py" in edit 571. mf.save() File "./freenasUI/system/forms.py" in save 1747. pk = c.call('systemdataset.update', data) File "./freenasUI/system/forms.py" in save 1747. pk = c.call('systemdataset.update', data) File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py" in call 394. raise ClientException(c.error, c.errno, c.trace, c.extra) Exception Type: ClientException at /admin/system/systemdataset/edit/1/ Exception Value: [Errno 66] Directory not empty: '/tmp/system.new' Request information GET Variable Value inline 'true' POST Variable Value __all__ '' sys_pool 'Plugins' sys_syslog_usedataset 'on' sys_rrd_usedataset 'on' __form_id 'dialogForm_systemdataset' FILES No FILES data
