I have TN Core installed that I have been using from many many years. I had set up ZFS replication on a Proxmox ZFS RAIDZ2 array as target. I exported the pool in the Proxmox server and then installed Scale on a different server and I imported the ZFS replication target as the pool so that I don't have to copy all the data from my CORE install. The import was successful, but the file system is read-only. I cannot change ownership of any directories or create new ones.
Researching this, I found this thread that indicates how to change it to RW : https://www.truenas.com/community/t...-and-making-the-destination-read-write.10551/
But I used the recommended install of only Admin account. So when I try to run the zfs command in the shell, it says command not found. How would I turn off the readonly flag on the pool and how would I assume root powers in the Shell if the root user password is disabled?
Thanks,
Thanks,
