r2p2
- Jan 29, 2019
I posted my question originally here here but was politely redirected. The following text is copied from the original.
I have a FreeNAS Mini running with a jail for Nextcloud. While moving my files from Dropbox to the Nextcloud instance, I realized that there are many fastcgi timeouts happening.
In order to investigate the cause, I observed a strange behavior which I don't really understand but my hope is that my Nextcloud synchronization problem will be fixed if I fix that behavior...
So what am I talking about?
If i connect to my FreeNAS via SSH and try to quit a vi instance with saving a file (
But when I join the Nextcloud jail (
When writing a file with dd is super fast in comparison. Both inside and outside the jail.
I cannot make any sense of these differences and how I can speedup those simple non-dd file operations.
Thanks in advance for any hints.
:wq
), than it takes about 3 - 4 seconds for vi to quit. That's already way to long for my taste. Especially if the file is empty.But when I join the Nextcloud jail (
iocage exec nextcloud sh
) and do the same there, vi needs not less than 9 seconds.When writing a file with dd is super fast in comparison. Both inside and outside the jail.
# dd if=/dev/zero of=data.dat bs=1k count=1 1+0 records in 1+0 records out 1024 bytes transferred in 0.000075 secs (13688559 bytes/sec)
