Hi there,
I just tried out the Freenas 8.3.1 Beta3 and build an encrypted ZFS pool . I selected "Force 4096 bytes sector size" "Enable full disk encryption" "Raid-z".
I then tested its thoughput by doing :
as you can see I got around 60 MB/s
how ever if I create the ZFS array myself in the console like this :
I get this
So around 240 MB/s
So it is a lot faster.
This is also true for a single drive pool, where I get around 140 MB/s when created manually and 80 when created via the GUI.
Is there something wrong perhaps with how the GUI creates the pool at the moment? Am I missing something ?
I don't know if I can use my manually created pool with the GUI since there is obviously something very different.
dd if=/dev/zero of=testfile bs=1M count=30000 30000+0 records in 30000+0 records out 31457280000 bytes transferred in 500.918654 secs (62799179 bytes/sec)
geli init -s 4096 ada0 # etc geli attach ada0 # etc zpool create bla raidz ada0.eli ada1.eli ada2.eli ada3.eli ada4.eli ada5.eli zfs set mountpoint=/mnt/bla bla zfs mount -a
I get this
dd if=/dev/zero of=testfile bs=1M count=30000 30000+0 records in 30000+0 records out 31457280000 bytes transferred in 128.580592 secs (244650297 bytes/sec)
So around 240 MB/s
