Unburned3156
- Jan 21, 2023
Whenever I try and install an app or create a docker container I get the below:
With the below in the more info box:
My Kubernetes settings are:
IP addresses are correct:
enp0s31f6 is my only interface configured in network settings.
I have tried:
I watch videos on Youtube and follow guides, they all just work, whereas I get this error.
I have once gotten a official app to install but it didn't deploy. I left it for an hr and ended up deleting it to try again.
My specs:
It seems to be working fine otherwise, I can access my fileshares normally from other devices.
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 461, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1152, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1284, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 397, in do_create await self.middleware.call('kubernetes.validate_k8s_setup') File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1306, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1255, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/update.py", line 496, in validate_k8s_setup raise CallError(error) middlewared.service_exception.CallError: [EFAULT] Kubernetes service is not running.
I have tried:
- Multiple reboots
- Unsetting Pool and resetting, multiple times
- Deleting the ix-applications from my dataset
- Creating a new custom directory to save the container configs
My specs:
- Boot disk: Crucial BX500 2.5in SATA SSD 240GB
- Data disks: 2x 8TB ST8000VN004 Seagate IronWolf SATA HDDs in RAID 1
- Drives connected via a LSI 6Gbps SAS HBA 9211-8i FW P20 in IT Mode
- Intel Core i5 12500 Processor
- ASRock B660M-ITX/ac DDR4 ITX Motherboard
- 1x 8GB DDR4 RAM
- Using Motherboard NIC
- TrueNAS-SCALE-22.12.0
