Issue with showing Zpool size?
mutation666
So I was looking at my freenas box and the storage size on my new pool seems wrong.
I have 4x3tb drives in raidZ2 its the 2nd pool called that. When I go to the storage tab on the freenas gui page it says 1.6tb used and 9.2 available. Shouldn't this be closer to 5TB available since raidz2 would eat two of the drives leaving me with less then what that says.
Running Version
FreeNAS-9.10-STABLE-201606270534 (dd17351)
[root@XXXXXXXXXXX ~]# zpool status
pool: MainStore
state: ONLINE
scan: scrub repaired 0 in 2h16m with 0 errors on Sun Jul 24 02:16:56 2016
NAME STATE READ WRITE CKSUM
MainStore ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/1cd99c1c-17ac-11e4-95fa-d050992dfdba ONLINE 0 0 0
gptid/1d8b878b-17ac-11e4-95fa-d050992dfdba ONLINE 0 0 0
gptid/1e4031b9-17ac-11e4-95fa-d050992dfdba ONLINE 0 0 0
errors: No known data errors
pool: RaidZ2
state: ONLINE
scan: scrub repaired 0 in 0h0m with 0 errors on Sun Jul 17 00:00:04 2016
RaidZ2 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/58b74426-1fc7-11e6-9a65-d050992dfdba ONLINE 0 0 0
gptid/59bec8aa-1fc7-11e6-9a65-d050992dfdba ONLINE 0 0 0
gptid/5ab9bfa6-1fc7-11e6-9a65-d050992dfdba ONLINE 0 0 0
gptid/5bae67af-1fc7-11e6-9a65-d050992dfdba ONLINE 0 0 0
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h6m with 0 errors on Mon Jul 11 03:51:54 2016
freenas-boot ONLINE 0 0 0
gptid/00c301a6-ba39-11e4-892d-d050992dfdba ONLINE 0 0 0
mutation666
Figured this might help
yKi3wqVd5BuDW3sJ-LrQVjx_X7HIV2cTDgqD3mU6bKJ-AJ_RsApLKei6IvDvW6S6mbNQoN4MRAWwq3yg7JnhOn0b7SQT_08oAPgn-0w98Wkuw64b8VzcmLmoMvwix3OVYrR36J4qkb3ExQ2MgXeOKCXP95IR5yTqLOQD7IJ4Qe6hwxp9oqCHj2Jr_NOLgtjnZLLF-jdhDGe55nIeI7SSPWh-HXod8ap7edHIKpel9hpW1tZqeM6XRib0v7Wu9QPAhP9CFZk2vzo4Nt_EghQNq1BwneSNExQx_qFoiB7i6yqpAMav1bnUJfrGKlIc48EUO15b7N_IWFnxpPIDCEKE_pqjshdo0fJVd35mxPFZAQNX_esNwl7GQPHXYxqjZxHhQbyiytxzwoohRA6PBT55zho1_xvbi6A7zV3B8BTRShz0OhHv7txldWpwbkfZtUQNqsh8Jjd_VAUDWZRe_AW93ZssBxcKPdM_ptbRxyWApjL7NvX1D_Rhmv4gawP5mb66Ayme7ZnP_7Oq_CMHymMo5da2v8DXZMgSb-cIrBVBYSc40Qjy1MwLUeh1LXVBRMU81O6g2e6FSXjKx9qmEhKMFprZpXB0yuE=w1181-h223-no
gpsguy
Active Member
Ignore the first line, that's your raw amount.
Instead, look at the second line, which when you add the "used + available" is just over 5TiB.
gpsguy
Active Member
No worries, users are often confused by the two lines.
