Issue updating iocage release version
White95supra
I have plex installed in a iocage jail since the 11.2 beta, the issue I have is that the iocage release version on the jail is 11.1-RELEASE-P11 and not the current version of 11.2-RELEASE-P4. As I understand with iocage, having different versions between the server and the jail can cause issues. So after some googling, I tried stopping the jail, going to edit in the GUI and changing the version to 11.2-RELEASE and saving but it did not change anything. The other option I found was upgrading through CLI as per these iocage docs but this is all that happens
iocage upgrade plex -r 11.2-RELEASE
Snapshotting plex...
Updating plugin INDEX...
/mnt/ssd_drive/iocage/.plugin_index/plex.json was not found!
Any help would be appreciated.
Skro
Did you install Plex using the plugin, pkg, or ports?
I installed Plex in 11.1-u6, RC1, and RC2 using ports and was unable to update using the GUI, but had no issue using the CLI method to update to 11.2. There is a bug that sounds similar (#54234) but it looks like they couldn't reproduce it. You might want to provide some more details and perhaps one of the gurus can help.
White95supra
This was installed through plugins. I am not sure if that bug is the same or not, I can't tell what caused the error in the bug report.
Jailer
Not strong, but bad
What is the output of iocage list
White95supra
iocage list
| JID |    NAME    | STATE |   RELEASE    |    IP4     |
| 15  | plex       | up    | 11.1-RELEASE | 10.0.1.102 |
| 2   | tautulli   | up    | 11.2-RELEASE | 10.0.1.104 |
| -   | zoneminder | down  | 11.2-RELEASE | 10.0.1.105 |
