optikul81
- Oct 12, 2015
First, here is the setup I am using:
Dell PE R410
FreeNAS 9.10.2-U1
2x Xeon e5520 Quad Core CPUs
12GB ECC RAM
4x 2TB Seagate Constellation ES drives in Raid Z1
1x 16GB Sandisk Cruzer as Boot drive
DELL PERC 6/IR (Flashed to LSI IT Firmware)
Dual Broadcom 1GB NICS
Primary Interface - 10.1.100.217/24
Alias 10.1.101.129/25
Secondary Interface - 10.1.101.1/25
Connected to Dell PowerConnect 5448 Gigabit Managed switch. LACP is not being used.
Connected to Dell PE R610
XenServer 7.0
Interface 1 - 10.1.101.2/25
Interface 2 - 10.1.101.130/25
I have both IPs listed under Portal 1
Under Xen, it shows both paths as connected (2 of 2 paths active)
* LUN Selected to allow Multipath
During testing, I am only getting 110MB/s max transfers using CrystalDiskMark 5.1.2 x64
FreeNAS is showing only one path is being used. bce0 is the primary interface and is the only one being utilized while bce1 is sitting idle.
Any idea's what I could be doing wrong in the configuration? This is just for a home lab, so the speed is not an absolute must. But since I can't add a 10GB card to the R410, this is the only choice I have to increase bandwidth.
Thanks!
Dell PE R410
FreeNAS 9.10.2-U1
12GB ECC RAM
XenServer 7.0
Thanks!
