My Setup:
portal 1 ips: 10.3.0.1 ; 10.4.0.1
I was able to setup iSCSI onn Xenserver side, no issues. During setup, I entered both Portal IPs above, picked * (which means multipath) and picked LUN.
I could transfer some files over iSCSI storage. So far so good. But only one nic is handling traffic.
Please check outputs from XenServer. Both portals has been discovered, using portal IPs:
# iscsiadm -m discovery --type sendtargets --portal 10.3.0.1
10.3.0.1:3260,3 iqn.2011-03.org.accsan1.istgt:accnas03
10.4.0.1:3260,3 iqn.2011-03.org.accsan1.istgt:accnas03
# iscsiadm -m discovery --type sendtargets --portal 10.4.0.1
Now check my LAN traffic:
xenbr1 Link encap:Ethernet
inet addr:10.3.0.2 Bcast:10.3.0.255 Mask:255.255.255.0
RX bytes:19368971114 (18.0 GiB) TX bytes:99007486765 (92.2 GiB)
xenbr2 Link encap:Ethernet
inet addr:10.4.0.2 Bcast:10.4.0.255 Mask:255.255.255.0
RX bytes:20908927 (19.9 MiB) TX bytes:4246713 (4.0 MiB)
RX and TX from both nics seems that xenbr2 interface (10.4.0.2) is barely being used.
My question here is, is there something on FreeNAS side that I have to check at this point? For me, FreeNAS seems to be fine, but just wanted to check if someone already experiencied similar issues.
