Since when did iSCSI/fibre channel extents show up under view disks in the GUI!?!one?1!
kdragon75 Wizard Joined Aug 7, 2016 Messages 2,457 Aug 12, 2018 #1 Since when did iSCSI/fibre channel extents show up under view disks in the GUI!?!one?1!
Ericloewe Server Wrangler Moderator Joined Feb 15, 2014 Messages 20,194 Aug 12, 2018 #2 I understand why they're there, but it doesn't feel right. I'd file a bug report for it.
kdragon75 Wizard Joined Aug 7, 2016 Messages 2,457 Aug 12, 2018 #3 Hmmm... ZFS on ZFS? LETS TRY IT! jk
pro lamer Guru Joined Feb 16, 2018 Messages 626 Aug 12, 2018 #4 kdragon75 said: Hmmm... ZFS on ZFS? LETS TRY IT! jk Click to expand... Zfs on geli on zvol on unencrypted zfs
Ericloewe Server Wrangler Moderator Joined Feb 15, 2014 Messages 20,194 Aug 13, 2018 #5 Might as well wait for native encryption...
pro lamer Guru Joined Feb 16, 2018 Messages 626 Aug 13, 2018 #6 kdragon75 said: iSCSI/fibre channel extents show up under view disks in the GUI Click to expand... Might it have anything to do with the zvol tunable? Or with this: wblock said: create a pool using partitions, then import it in the GUI. I'm hesitant to give more detail, because that might imply I think this a good idea. Click to expand... ? disclaimer: I don't mean @kdragon75 did anything being a bad idea... Ericloewe said: Might as well wait for native encryption... Click to expand... Why? I really am considering doing that (that = geli on top of zfs) Sent from my mobile phone
Ericloewe Server Wrangler Moderator Joined Feb 15, 2014 Messages 20,194 Aug 13, 2018 #7 pro lamer said: Why? I really am considering doing that (that = geli on top of zfs) Click to expand... Because managing that is a pain and you have all the problems inherent to virtual block devices in terms of performance.
pro lamer Guru Joined Feb 16, 2018 Messages 626 Aug 19, 2018 #8 Ericloewe said: you have all the problems inherent to virtual block devices in terms of performance. Click to expand... Like: Veracrypt/truecrypt container file? Bitlocker on iSCSI? Or worse?
Ericloewe Server Wrangler Moderator Joined Feb 15, 2014 Messages 20,194 Aug 20, 2018 #9 Shouldn't be worse
