after one week of fighting with FreeNas 11.2 trying to recover the previous data I decided to delete everything and to restart from scratch, loosing all my data (...).
I have a 12 disks 450Gb 15K box and a 12 disks 2Tb 7.2K box connected with Fiber Channel adapter.
Previously I had FreeNas 9.3 and everything was working fine connecting my vmware lab with iScsi.
After deleting everything I create 2 pools, one for the fast disks and one for the normal disks.
I have created the pool correctly and they are healthy.
Now the problem is the iScsi configuration.
I have created two targets: vm-fast-pool and vm-sata-pool and I would like to discover them as a volume to mount in vmware.
Now from this interface it is not possible to create any dataset or volume.
I have created one extents for each disk. The documentation is not clear.
Is it correct? Why from the UI everytime you want to define a new extent or edit one you do not have already selected the previous disk and you can select any disk also if previously selected?
I have tried to associate the extents with the target, it means that each extent has a different LUN and it looks to me not correct.
I have associated 12 extent to the first target correctly, I am trying to associate the other 12 extents to the other target BUT after the 8th extent I cannot see the remaining four, there is some limits?
I am not able to discover the two targets from my esx servers.
Do I have to do something more from FreeNas?
Thanks for your help.
