Hi everyone,
I understand that you're only supposed to use 50% of the storage space when using iSCSI for FreeNAS and VMware as a best practice but I'm just unclear regarding what that 50% means. Let me give you an example:
Phiysical disks: 4x 1 TB HDD's
Volume configured as striped mirror, so 2 TB total usable space.
To follow this 50% rule do you:
A: Create a 1 TB zvol file extent, thereby only using 50% of the total volume's space, and then allocated all 1 TB of that file extent to the iSCSI target in VMware ESXi?
B: Create a 2 TB zvol file extent, thereby using 100% of the total volume's space, but then set Target Global Configuration -> Pool Available Space Threshold -> 50% and Extents -> Properties of the ESXi extent -> Available Space Threshold -> 50% and then make sure to only allocate less than 1 TB (50%) when I add the iSCSI target in VMware?
C: Something else?
C: Something else?
