sudo smartctl -x /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.1.74-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke,
www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N3NFS4TY
LU WWN Device Id: 5 0014ee 2bb48e0f9
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
Device is: In smartctl database 7.3/5528
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Mar 27 22:37:11 2024 CET
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: (40020) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 401) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 186 177 021 - 5691
4 Start_Stop_Count -O--CK 100 100 000 - 280
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 099 099 000 - 1216
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 78
192 Power-Off_Retract_Count -O--CK 200 200 000 - 52
193 Load_Cycle_Count -O--CK 200 200 000 - 282
194 Temperature_Celsius -O---K 122 101 000 - 28
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x0c GPL R/O 2048 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 1
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 1 [0] occurred at disk power-on lifetime: 1091 hours (45 days + 11 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 00 00 00 85 06 4a 20 40 00 Error: UNC at LBA = 0x85064a20 = 2231781920
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 04 08 00 38 00 00 85 06 4a 20 40 08 23:27:41.649 READ FPDMA QUEUED
60 04 00 00 b8 00 00 85 06 10 00 40 08 23:27:41.646 READ FPDMA QUEUED
60 01 00 00 88 00 00 85 05 b6 a8 40 08 23:27:41.640 READ FPDMA QUEUED
60 02 00 00 f8 00 00 85 05 b3 e0 40 08 23:27:41.635 READ FPDMA QUEUED
60 02 00 00 28 00 00 85 05 94 e0 40 08 23:27:41.631 READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed without error 00% 1195 -
# 2 Short offline Completed without error 00% 1173 -
# 3 Short offline Completed without error 00% 1147 -
# 4 Short offline Completed without error 00% 1134 -
# 5 Extended offline Completed without error 00% 1075 -
# 6 Short offline Completed without error 00% 1057 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 28 Celsius
Power Cycle Min/Max Temperature: 21/29 Celsius
Lifetime Min/Max Temperature: 18/49 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (276)
Index Estimated Time Temperature Celsius
277 2024-03-27 14:40 28 *********
... ..( 7 skipped). .. *********
285 2024-03-27 14:48 28 *********
286 2024-03-27 14:49 27 ********
... ..( 16 skipped). .. ********
303 2024-03-27 15:06 27 ********
304 2024-03-27 15:07 28 *********
... ..( 21 skipped). .. *********
326 2024-03-27 15:29 28 *********
327 2024-03-27 15:30 29 **********
... ..(424 skipped). .. **********
274 2024-03-27 22:35 29 **********
275 2024-03-27 22:36 28 *********
276 2024-03-27 22:37 28 *********
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 2) ==
0x01 0x008 4 78 --- Lifetime Power-On Resets
0x01 0x010 4 1216 --- Power-on Hours
0x01 0x018 6 19864133761 --- Logical Sectors Written
0x01 0x020 6 49559047 --- Number of Write Commands
0x01 0x028 6 46422368030 --- Logical Sectors Read
0x01 0x030 6 114363245 --- Number of Read Commands
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 800 --- Spindle Motor Power-on Hours
0x03 0x010 4 791 --- Head Flying Hours
0x03 0x018 4 335 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 1 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 1 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 65537 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 27 --- Current Temperature
0x05 0x010 1 27 --- Average Short Term Temperature
0x05 0x018 1 33 --- Average Long Term Temperature
0x05 0x020 1 48 --- Highest Temperature
0x05 0x028 1 18 --- Lowest Temperature
0x05 0x030 1 44 --- Highest Average Short Term Temperature
0x05 0x038 1 22 --- Lowest Average Short Term Temperature
0x05 0x040 1 34 --- Highest Average Long Term Temperature
0x05 0x048 1 33 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 60 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 348 --- Number of Hardware Resets
0x06 0x010 4 184209 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 2 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 3 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 84059 Vendor specific
