n00b-beginnings
- Oct 12, 2020
I have this SeaGate Barracuda - ada5 -which has been "reporting" offline uncorrectable sectors. Currently the number is 1048 Offline Uncorrectable Sectors.
During a File Transfer Into the Server yesterday it climed over 2000 and then began to fall back down to its current level of 1048.
Here are the results of smartctl -x /dev/ada5
I'm just having a bit of confusion sorting it out.... thanks for your help.
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p11 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST1000DM003-9YN162
Serial Number: S1D48MLX
LU WWN Device Id: 5 000c50 051da60a1
Firmware Version: CC4B
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Oct 12 14:01:36 2020 CDT
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Disabled
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Unavailable
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: ( 575) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 113) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 110 078 006 - 28943440
3 Spin_Up_Time PO---- 098 097 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 192
5 Reallocated_Sector_Ct PO--CK 076 076 036 - 32672
7 Seek_Error_Rate POSR-- 079 060 030 - 86318164
9 Power_On_Hours -O--CK 065 065 000 - 31173
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 100 100 020 - 189
183 Runtime_Bad_Block -O--CK 100 100 000 - 0
184 End-to-End_Error -O--CK 100 100 099 - 0
187 Reported_Uncorrect -O--CK 001 001 000 - 6277
188 Command_Timeout -O--CK 100 098 000 - 5 6 6
189 High_Fly_Writes -O-RCK 001 001 000 - 2990
190 Airflow_Temperature_Cel -O---K 062 043 045 Past 38 (Min/Max 38/49 #373)
191 G-Sense_Error_Rate -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 100 100 000 - 134
193 Load_Cycle_Count -O--CK 001 001 000 - 411683
194 Temperature_Celsius -O---K 038 057 000 - 38 (0 21 0 0 0)
197 Current_Pending_Sector -O--C- 094 001 000 - 1048
198 Offline_Uncorrectable ----C- 094 001 000 - 1048
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
240 Head_Flying_Hours ------ 100 253 000 - 28982h+37m+10.693s
241 Total_LBAs_Written ------ 100 253 000 - 19867594008778
242 Total_LBAs_Read ------ 100 253 000 - 229512760525437
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 20 Device vendor specific log
0xa2 GPL VS 4496 Device vendor specific log
0xa8 GPL,SL VS 20 Device vendor specific log
0xa9 GPL,SL VS 1 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xb0 GPL VS 5067 Device vendor specific log
0xbd GPL VS 512 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
Device Error Count: 37 (device log contains only the most recent 20 errors)
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 37 [16] occurred at disk power-on lifetime: 31122 hours (1296 days + 18 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 00 00 00 73 16 bb 00 00 00 Error: UNC at LBA = 0x7316bb00 = 1930869504
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 00 00 01 00 00 00 73 16 b5 98 40 00 22:27:03.686 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 ba 98 40 00 22:27:03.686 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 00 00 22:27:03.578 READ LOG EXT
60 00 00 01 00 00 00 73 16 b5 98 40 00 22:27:00.794 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 ba 98 40 00 22:27:00.793 READ FPDMA QUEUED
Error 36 [15] occurred at disk power-on lifetime: 31122 hours (1296 days + 18 hours)
2f 00 00 00 01 00 00 00 00 00 10 00 00 22:27:00.694 READ LOG EXT
60 00 00 01 00 00 00 73 16 b5 98 40 00 22:26:57.836 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 ba 98 40 00 22:26:57.836 READ FPDMA QUEUED
Error 35 [14] occurred at disk power-on lifetime: 31122 hours (1296 days + 18 hours)
2f 00 00 00 01 00 00 00 00 00 10 00 00 22:26:57.802 READ LOG EXT
60 00 00 01 00 00 00 73 16 b5 98 40 00 22:26:54.930 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 bc 98 40 00 22:26:54.929 READ FPDMA QUEUED
Error 34 [13] occurred at disk power-on lifetime: 31122 hours (1296 days + 18 hours)
60 00 00 01 00 00 00 73 16 ba 98 40 00 22:26:54.929 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 00 00 22:26:54.885 READ LOG EXT
60 00 00 01 00 00 00 73 16 bc 98 40 00 22:26:52.124 READ FPDMA QUEUED
Error 33 [12] occurred at disk power-on lifetime: 31122 hours (1296 days + 18 hours)
60 00 00 01 00 00 00 73 16 b7 98 40 00 22:26:52.110 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 b6 98 40 00 22:26:52.088 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 bb 98 40 00 22:26:52.088 READ FPDMA QUEUED
61 00 00 00 10 00 00 00 40 02 90 40 00 22:26:52.087 WRITE FPDMA QUEUED
Error 32 [11] occurred at disk power-on lifetime: 31122 hours (1296 days + 18 hours)
60 00 00 01 00 00 00 73 16 c4 98 40 00 22:26:49.100 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c3 98 40 00 22:26:49.100 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c2 98 40 00 22:26:49.100 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c1 98 40 00 22:26:49.100 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c0 98 40 00 22:26:49.100 READ FPDMA QUEUED
Error 31 [10] occurred at disk power-on lifetime: 31122 hours (1296 days + 18 hours)
60 00 00 01 00 00 00 73 16 c4 98 40 00 22:26:46.216 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c3 98 40 00 22:26:46.216 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c2 98 40 00 22:26:46.216 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c1 98 40 00 22:26:46.216 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c0 98 40 00 22:26:46.216 READ FPDMA QUEUED
Error 30 [9] occurred at disk power-on lifetime: 31122 hours (1296 days + 18 hours)
60 00 00 01 00 00 00 73 16 c4 98 40 00 22:26:43.333 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c3 98 40 00 22:26:43.333 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c2 98 40 00 22:26:43.332 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c1 98 40 00 22:26:43.332 READ FPDMA QUEUED
60 00 00 01 00 00 00 73 16 c0 98 40 00 22:26:43.332 READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed: read failure 90% 31172 1930869504
# 2 Extended offline Completed: read failure 90% 31146 1930869504
# 3 Extended offline Completed: read failure 90% 31105 15031272
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 522 (0x020a)
Device State: Active (0)
Current Temperature: 38 Celsius
Power Cycle Min/Max Temperature: 38/49 Celsius
Lifetime Min/Max Temperature: 21/57 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Data Table command not supported
SCT Error Recovery Control command not supported
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 12 Device-to-host register FISes sent due to a COM
Firmware Updates for Seagate Products | Support Seagate US
Seagate currently has firmware updates for certain drive families. Check here to see if an update is available.
knowledge.seagate.com
command.
power-saving mode.
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
ER = Error register
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
