If it actually is a 2TB disk, yes its toast. You can also check the disk size from "smartctl -a /dev/ada4". If it reports anything except 2TB and it is a 2TB drive your firmware has taken a dump and you should RMA/replace it appropriately.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
