<div class="bbWrapper">ZFS isn't picky about hardware at all. You can do all sorts of bad, silly, dumb, clever, etc., stuff.<br />
<br />
Don't confuse ZFS with FreeBSD. FreeBSD really needs stuff like decent HBA and ethernet controllers in order to provide a good NAS experience.<br />
<br />
I generally recommend heterogeneous pools (pools made up of devices not all from the same mfr) for various reasons. I'm not sure mixing 3.5 and 2.5 drives is a good idea, but it probably wouldn't kill you.</div>
<div class="bbWrapper"><blockquote data-attributes="member: 115" data-quote="jgreco" data-source="post: 582182"
class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
<div class="bbCodeBlock-title">
<a href="/community/goto/post?id=582182"
class="bbCodeBlock-sourceJump"
rel="nofollow"
data-xf-click="attribution"
data-content-selector="#post-582182">jgreco said:</a>
</div>
<div class="bbCodeBlock-content">
<div class="bbCodeBlock-expandContent js-expandContent ">
Ahhhh... yes, but you probably don't want to, most 2.5" 2TB drives are SMR, I think.
</div>
<div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div>
</div>
</blockquote><br />
They are, mostly. Check the list of SMR drives and particularly for 2.5”, check against the additional list references in the notes there.<br />
<br />
3.5” is a safer bet, just avoid the wd red efax 2/4/6TB, and any “not nas” drives such as barracuda. Red pro, ironwolf / pro, n300 are all safe choices.</div>
<div class="bbWrapper">Thanks ! - <br />
Yes - I was thinking IronWolf ... watched some YT videos yest about that sneaky SMR on WD Reds (which I almost got) and then I saw the Seagate drives (not IW) were SMR...good to know also about WD Red Pro -- looking forward to adding the storage ...will need to convert 5.25 drive bays for extra 3.5 drives ... thank you all --</div>
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
