martian9000
- Nov 21, 2023
Howdy folks, I have a pool comprised of three VDEVs:
Data VDEV: 3 x 4TB drives in 3 way mirror
Data VDEV: 3 x 10TB drives in 3 way mirror
Metadata VDEV: 2 x 110GB drives in 2 way mirror
I'm consolidating two systems in to one to save on electricity. I'm not 100% sure the new system will support bifurcation for the 2 110GB Optane drives which is why I'd like to explore removing them from the pool now in case I run in to issues during hardware rebuild. I've read similar posts indicating you can't remove a metadata VDEV if you're running any sort of RAIDZ. All of my VDEV are comprised of mirrors, however.
The TrueNAS SCALE GUI will let me click a button to remove the metadata mirror from the pool. My question is: what actually happens behind the scenes when I click to remove the metadata VDEV? Will TrueNAS copy all metadata back to the main data VDEVs or will it happily remove the metadata VDEV, thereby nuking the pool? Many thanks in advance.
