My 16 GB RAM freenas 9.10
when i monitor the cpu and ram using. I saw the memory wired are 14G, The Free Ram are only 300M
I find Wired mean : Memory in use by the Kernel. This memory cannot be swapped out
It is because I have two same model mini server
server 1 : (same cpu) 10 GB RAM- Two harddisk 8TB total
server 2: (same cpu) 16 GB RAM- Four harddisk 16TB total
I tested on same network cable. I copy the file from PC to server 1 : 60 MB/S
But server 2: 40 MB/S only.
The kern.ipc.somaxconn tunable was changed to kern.ipc.soacceptqueue in freeBSD 10, so if you're running freeNAS 9.10 you'll want to change that, just FYI.
