My 16 GB RAM freenas 9.10
when i monitor the cpu and ram using. I saw the memory wired are 14G, The Free Ram are only 300M
I find Wired mean : Memory in use by the Kernel. This memory cannot be swapped out
It is because I have two same model mini server
server 1 : (same cpu) 10 GB RAM- Two harddisk 8TB total
server 2: (same cpu) 16 GB RAM- Four harddisk 16TB total
I tested on same network cable. I copy the file from PC to server 1 : 60 MB/S
But server 2: 40 MB/S only.
The kern.ipc.somaxconn tunable was changed to kern.ipc.soacceptqueue in freeBSD 10, so if you're running freeNAS 9.10 you'll want to change that, just FYI.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
