Hi Guys, . i'm running ESXi 6.7 with FN VM 11.2 U3 and trying to set the FAN threshold using ipmitool but its not working i get an error
in directory /dev/ ipmi device is missing, but the driver is loaded
as well no problem accessing the IPMI web UI all normal can make any changes just ipmitool on freenas not available
please help, is there anyway to test where the issues is and how to fix it/workaround?
Thank you
root@freenas[/]# ipmitool Could not open device at /dev/ipmi0 or /dev/ipmi/0 or /dev/ipmidev/0: No such file or directory
root@freenas ~]# find / -name "ipmitool" /usr/local/bin/ipmitool /usr/local/share/ipmitool [root@freenas ~]# kldload ipmi kldload: can't load ipmi: module already loaded or in kernel [root@freenas ~]# dmesg | grep -i ipmi [root@freenas ~]# dmidecode | grep -i ipmi [root@freenas ~]# kldload ipmi.ko kldload: can't load ipmi.ko: module already loaded or in kernel [root@freenas ~]# kldstat Id Refs Address Size Name 1 73 0xffffffff80200000 251f110 kernel 2 1 0xffffffff82721000 100eb0 ispfw.ko 3 1 0xffffffff82822000 f9f8 ipmi.ko 4 2 0xffffffff82832000 2d28 smbus.ko 5 1 0xffffffff82835000 8a10 freenas_sysctl.ko 6 1 0xffffffff82a19000 32e048 vmm.ko 7 1 0xffffffff82d48000 a74 nmdm.ko 8 1 0xffffffff82d49000 e610 geom_mirror.ko 9 1 0xffffffff82d58000 3a3c geom_multipath.ko 10 1 0xffffffff82d5c000 2ec dtraceall.ko 11 9 0xffffffff82d5d000 3acf8 dtrace.ko 12 1 0xffffffff82d98000 5b8 dtmalloc.ko 13 1 0xffffffff82d99000 1898 dtnfscl.ko 14 1 0xffffffff82d9b000 1d31 fbt.ko 15 1 0xffffffff82d9d000 53390 fasttrap.ko 16 1 0xffffffff82df1000 bfc sdt.ko 17 1 0xffffffff82df2000 6d80 systrace.ko 18 1 0xffffffff82df9000 6d48 systrace_freebsd32.ko 19 1 0xffffffff82e00000 f9c profile.ko 20 1 0xffffffff82e01000 13ec0 hwpmc.ko 21 1 0xffffffff82e15000 7340 t3_tom.ko 22 2 0xffffffff82e1d000 ab8 toecore.ko 23 1 0xffffffff82e1e000 ddac t4_tom.ko 24 1 0xffffffff82e2c000 2798 vmmemctl.ko 25 1 0xffffffff82e2f000 23e0 vmxnet.ko 26 1 0xffffffff82e32000 2d08 vmblock.ko 27 1 0xffffffff82e35000 17a0 uhid.ko [root@freenas ~]#
Thank you
