TrueNAS-SCALE-22.02.0.1
Supermicro; X12SPi-TF
Network: bonded/Lagg
Console: dedicated network port
Hi, when testing some startup scripts to make some modifications via IPMITOOL, I noticed I couldn't resolve the IP. I tested this on my local terminal and got the following (Which worked):
However, I try this from a terminal on my TrueNAS Scale box, I get the following:
Why would it look to `172.17.0.1`? This would explain why it can't reach that host/ipmi. I don't know what would cause this to happen? Even the GUI see's the IPMI is available and clicking manage, drops me into a browser at the correct IP. TrueNAS Scale and IPMI are on different VLANs. Not sure if this is an issue for TrueNAS?
Any help is much appreciated.
ping 172.17.17.20 PING 172.17.17.20 (172.17.17.20) 56(84) bytes of data. 64 bytes from 172.17.17.20: icmp_seq=1 ttl=62 time=0.783 ms 64 bytes from 172.17.17.20: icmp_seq=2 ttl=62 time=0.783 ms
ping 172.17.17.20 PING 172.17.17.20(172.17.17.20) 56(84) bytes of data. From 172.17.0.1 icmp_seq=1 Destination Host Unreachable From 172.17.0.1 icmp_seq=2 Destination Host Unreachable
