Hello All,
When I try to passthrough my 3060 to a VM on my machine I get the below error even though I am passing through both PCI devices for the card like I did with a 1080 in the same system.
"PCI device does not have a reset mechanism defined and you may experience inconsistent/degraded behavior when starting/stopping the VM."
I am trying to passthrough 01:00.0)pci_0000_01_00_0) and 01:00.1 (pci_0000_01_00_1) which is what is listed in LSPCI.
I did set it to be an isolated gpu in settings first, then reboot and add to the vm and got that error.
When I try to start the VM after saying okay to that error I am getting this error:
The two that I passed through are the only two in that grouping.
Here are some other checks I made on it:
Any advice or pointers would be greatly appreciated.
[EFAULT] internal error: qemu unexpectedly closed the monitor: 2023-03-09T22:03:24.995117Z qemu-system-x86_64: -device vfio-pci,host=0000:01:00.1,id=hostdev0,bus=pci.0,addr=0x7: vfio 0000:01:00.1: group 1 is not viable Please ensure all devices within the iommu_group are bound to their vfio bus driver.
admin@CoffeeNAS[~]$ sudo dmesg | grep -i nvidia [ 24.994188] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input7 [ 24.994240] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8 [ 24.994284] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9 [ 24.994330] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10 [ 24.994456] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11 [ 24.994531] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12 [ 24.994660] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13 [ 25.549831] nvidia-nvlink: Nvlink Core is being initialized, major device number 240 [ 25.551530] nvidia 0000:01:00.0: enabling device (0000 -> 0003) [ 25.552796] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none [ 25.598780] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022 [ 26.288540] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 515.65.01 Wed Jul 20 13:43:59 UTC 2022 [ 26.499878] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver [ 26.502016] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1 [ 141.925355] audit: type=1400 audit(1678398752.763:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=4272 comm="apparmor_parser" [ 141.926172] audit: type=1400 audit(1678398752.763:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=4272 comm="apparmor_parser" admin@CoffeeNAS[~]$ sudo nvidia-smi Thu Mar 9 16:59:28 2023 +-----------------------------------------------------------------------------+ | NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A | | 0% 57C P0 37W / 170W | 0MiB / 12288MiB | 6% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | No running processes found | +-----------------------------------------------------------------------------+ admin@CoffeeNAS[~]$ lspci 00:00.0 Host bridge: Intel Corporation 8th/9th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 0a) 00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 0a) 00:01.1 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) (rev 0a) 00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630] 00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10) 00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10) 00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10) 00:14.3 Network controller: Intel Corporation Wireless-AC 9560 [Jefferson Peak] (rev 10) 00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10) 00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10) 00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #17 (rev f0) 00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #1 (rev f0) 00:1c.5 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #6 (rev f0) 00:1c.7 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #8 (rev f0) 00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0) 00:1f.0 ISA bridge: Intel Corporation Z390 Chipset LPC/eSPI Controller (rev 10) 00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10) 00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10) 00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10) 00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10) 01:00.0 VGA compatible controller: NVIDIA Corporation Device 2504 (rev a1) 01:00.1 Audio device: NVIDIA Corporation Device 228e (rev a1) 02:00.0 PCI bridge: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA (rev ca) 03:00.0 PCI bridge: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA (rev ca) 03:08.0 PCI bridge: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA (rev ca) 03:09.0 PCI bridge: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA (rev ca) 04:00.0 Serial Attached SCSI controller: Broadcom / LSI SAS3008 PCI-Express Fusion-MPT SAS-3 (rev 02) 06:00.0 Serial Attached SCSI controller: Broadcom / LSI SAS3008 PCI-Express Fusion-MPT SAS-3 (rev 02) 09:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 10) 0a:00.0 Ethernet controller: Intel Corporation Ethernet Controller I225-V (rev 03) full error in: Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 160, in start if self.domain.create() < 0: File "/usr/lib/python3/dist-packages/libvirt.py", line 1353, in create raise libvirtError('virDomainCreate() failed') libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor: 2023-03-10T01:29:25.738321Z qemu-system-x86_64: -device vfio-pci,host=0000:01:00.0,id=hostdev0,bus=pci.0,addr=0x6: vfio 0000:01:00.0: group 1 is not viable Please ensure all devices within the iommu_group are bound to their vfio bus driver. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 196, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1335, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1318, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 46, in start await self.middleware.run_in_thread(self._start, vm['name']) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1252, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1249, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 68, in _start self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name)) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 169, in start raise CallError('\n'.join(errors)) middlewared.service_exception.CallError: [EFAULT] internal error: qemu unexpectedly closed the monitor: 2023-03-10T01:29:25.738321Z qemu-system-x86_64: -device vfio-pci,host=0000:01:00.0,id=hostdev0,bus=pci.0,addr=0x6: vfio 0000:01:00.0: group 1 is not viable Please ensure all devices within the iommu_group are bound to their vfio bus driver. As well as the lspci verbose output Looks like there is a lot of stuff in group 1, not sure if that is a problem: root@CoffeeNAS[~]# lspci -v 00:00.0 Host bridge: Intel Corporation 8th/9th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 0a) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd 8th/9th Gen Core 8-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] Flags: bus master, fast devsel, latency 0, IOMMU group 0 Capabilities: [e0] Vendor Specific Information: Len=10 <?> Kernel driver in use: skl_uncore Kernel modules: ie31200_edac 00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 0a) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 1 Bus: primary=00, secondary=01, subordinate=01, sec-latency=0 I/O behind bridge: 00005000-00005fff [size=4K] Memory behind bridge: 60000000-630fffff [size=49M] Prefetchable memory behind bridge: 0000000050000000-000000005fffffff [size=256M] Capabilities: [88] Subsystem: Gigabyte Technology Co., Ltd 6th-9th Gen Core Processor PCIe Controller (x16) Capabilities: [80] Power Management version 3 Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [a0] Express Root Port (Slot+), MSI 00 Capabilities: [100] Virtual Channel Capabilities: [140] Root Complex Link Capabilities: [d94] Secondary PCI Express Kernel driver in use: pcieport 00:01.1 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) (rev 0a) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 1 Bus: primary=00, secondary=02, subordinate=06, sec-latency=0 I/O behind bridge: 00003000-00004fff [size=8K] Memory behind bridge: 65100000-655fffff [size=5M] Prefetchable memory behind bridge: [disabled] Capabilities: [88] Subsystem: Gigabyte Technology Co., Ltd Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) Capabilities: [80] Power Management version 3 Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [a0] Express Root Port (Slot+), MSI 00 Capabilities: [100] Virtual Channel Capabilities: [140] Root Complex Link Capabilities: [d94] Secondary PCI Express Kernel driver in use: pcieport 00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630] (prog-if 00 [VGA controller]) DeviceName: Onboard - Video Subsystem: Gigabyte Technology Co., Ltd UHD Graphics 630 (Desktop 9 Series) Flags: bus master, fast devsel, latency 0, IRQ 182, IOMMU group 2 Memory at 64000000 (64-bit, non-prefetchable) [size=16M] Memory at 40000000 (64-bit, prefetchable) [size=256M] I/O ports at 6000 Expansion ROM at 000c0000 [virtual] [disabled] [size=128K] Capabilities: [40] Vendor Specific Information: Len=0c <?> Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00 Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [d0] Power Management version 2 Capabilities: [100] Process Address Space ID (PASID) Capabilities: [200] Address Translation Service (ATS) Capabilities: [300] Page Request Interface (PRI) Kernel driver in use: i915 Kernel modules: i915 00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH Thermal Controller Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 3 Memory at 65a41000 (64-bit, non-prefetchable) [size=4K] Capabilities: [50] Power Management version 3 Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit- Kernel driver in use: intel_pch_thermal Kernel modules: intel_pch_thermal 00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10) (prog-if 30 [XHCI]) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH USB 3.1 xHCI Host Controller Flags: bus master, medium devsel, latency 0, IRQ 135, IOMMU group 4 Memory at 65a20000 (64-bit, non-prefetchable) [size=64K] Capabilities: [70] Power Management version 2 Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+ Capabilities: [90] Vendor Specific Information: Len=14 <?> Kernel driver in use: xhci_hcd Kernel modules: xhci_pci 00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10) DeviceName: Onboard - Other Subsystem: Intel Corporation Cannon Lake PCH Shared SRAM Flags: bus master, fast devsel, latency 0, IOMMU group 4 Memory at 65a3a000 (64-bit, non-prefetchable) [size=8K] Memory at 65a40000 (64-bit, non-prefetchable) [size=4K] Capabilities: [80] Power Management version 3 00:14.3 Network controller: Intel Corporation Wireless-AC 9560 [Jefferson Peak] (rev 10) DeviceName: Onboard - Ethernet Subsystem: Intel Corporation Wireless-AC 9560 [Jefferson Peak] Flags: fast devsel, IRQ 16, IOMMU group 5 Memory at 65a34000 (64-bit, non-prefetchable) [size=16K] Capabilities: [c8] Power Management version 3 Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00 Capabilities: [80] MSI-X: Enable- Count=16 Masked- Capabilities: [100] Null Capabilities: [14c] Latency Tolerance Reporting Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?> Kernel modules: iwlwifi 00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH HECI Controller Flags: bus master, fast devsel, latency 0, IRQ 181, IOMMU group 6 Memory at 65a3f000 (64-bit, non-prefetchable) [size=4K] Capabilities: [50] Power Management version 3 Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [a4] Vendor Specific Information: Len=14 <?> Kernel driver in use: mei_me Kernel modules: mei_me 00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10) (prog-if 01 [AHCI 1.0]) DeviceName: Onboard - SATA Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH SATA AHCI Controller Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 134, IOMMU group 7 Memory at 65a38000 (32-bit, non-prefetchable) [size=8K] Memory at 65a3e000 (32-bit, non-prefetchable) I/O ports at 6090 I/O ports at 6080 I/O ports at 6060 Memory at 65a3d000 (32-bit, non-prefetchable) [size=2K] Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [70] Power Management version 3 Capabilities: [a8] SATA HBA v1.0 Kernel driver in use: ahci Kernel modules: ahci 00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #17 (rev f0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 124, IOMMU group 8 Bus: primary=00, secondary=07, subordinate=07, sec-latency=0 I/O behind bridge: [disabled] Memory behind bridge: [disabled] Prefetchable memory behind bridge: [disabled] Capabilities: [40] Express Root Port (Slot-), MSI 00 Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [90] Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH PCI Express Root Port Capabilities: [a0] Power Management version 3 Kernel driver in use: pcieport 00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #1 (rev f0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 125, IOMMU group 9 Bus: primary=00, secondary=08, subordinate=08, sec-latency=0 I/O behind bridge: [disabled] Memory behind bridge: [disabled] Prefetchable memory behind bridge: [disabled] Capabilities: [40] Express Root Port (Slot-), MSI 00 Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [90] Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH PCI Express Root Port Capabilities: [a0] Power Management version 3 Kernel driver in use: pcieport 00:1c.5 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #6 (rev f0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 126, IOMMU group 10 Bus: primary=00, secondary=09, subordinate=09, sec-latency=0 I/O behind bridge: [disabled] Memory behind bridge: 65900000-659fffff [size=1M] Prefetchable memory behind bridge: [disabled] Capabilities: [40] Express Root Port (Slot+), MSI 00 Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [90] Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH PCI Express Root Port Capabilities: [a0] Power Management version 3 Capabilities: [100] Advanced Error Reporting Capabilities: [140] Access Control Services Capabilities: [150] Precision Time Measurement Capabilities: [220] Secondary PCI Express Capabilities: [250] Downstream Port Containment Kernel driver in use: pcieport 00:1c.7 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #8 (rev f0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 127, IOMMU group 11 Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=0 I/O behind bridge: [disabled] Memory behind bridge: 65600000-658fffff [size=3M] Prefetchable memory behind bridge: [disabled] Capabilities: [40] Express Root Port (Slot+), MSI 00 Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [90] Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH PCI Express Root Port Capabilities: [a0] Power Management version 3 Capabilities: [100] Advanced Error Reporting Capabilities: [140] Access Control Services Capabilities: [150] Precision Time Measurement Capabilities: [220] Secondary PCI Express Capabilities: [250] Downstream Port Containment Kernel driver in use: pcieport 00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 128, IOMMU group 12 Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0 I/O behind bridge: 00007000-00007fff [size=4K] Memory behind bridge: 3f800000-3f9fffff [size=2M] Prefetchable memory behind bridge: 000000003fa00000-000000003fbfffff [size=2M] Capabilities: [40] Express Root Port (Slot+), MSI 00 Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit- Capabilities: [90] Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH PCI Express Root Port Capabilities: [a0] Power Management version 3 Kernel driver in use: pcieport 00:1f.0 ISA bridge: Intel Corporation Z390 Chipset LPC/eSPI Controller (rev 10) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Z390 Chipset LPC/eSPI Controller Flags: bus master, medium devsel, latency 0, IOMMU group 13 00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10) DeviceName: Onboard - Sound Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH cAVS Flags: bus master, fast devsel, latency 32, IRQ 183, IOMMU group 13 Memory at 65a30000 (64-bit, non-prefetchable) [size=16K] Memory at 65000000 (64-bit, non-prefetchable) [size=1M] Capabilities: [50] Power Management version 3 Capabilities: [80] Vendor Specific Information: Len=14 <?> Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+ Kernel driver in use: snd_hda_intel Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl 00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10) DeviceName: Onboard - Other Subsystem: Gigabyte Technology Co., Ltd Cannon Lake PCH SMBus Controller Flags: medium devsel, IRQ 16, IOMMU group 13 Memory at 65a3c000 (64-bit, non-prefetchable) I/O ports at efa0 Kernel driver in use: i801_smbus Kernel modules: i2c_i801 00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10) DeviceName: Onboard - Other Subsystem: Intel Corporation Cannon Lake PCH SPI Controller Flags: fast devsel, IOMMU group 13 Memory at fe010000 (32-bit, non-prefetchable) [size=4K] 00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10) DeviceName: Onboard - Ethernet Subsystem: Gigabyte Technology Co., Ltd Ethernet Connection (7) I219-V Flags: bus master, fast devsel, latency 0, IRQ 133, IOMMU group 13 Memory at 65a00000 (32-bit, non-prefetchable) [size=128K] Capabilities: [c8] Power Management version 3 Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+ Kernel driver in use: e1000e Kernel modules: e1000e 01:00.0 VGA compatible controller: NVIDIA Corporation Device 2504 (rev a1) (prog-if 00 [VGA controller]) Subsystem: eVga.com. Corp. Device 3656 Flags: fast devsel, IRQ 16, IOMMU group 1 Memory at 62000000 (32-bit, non-prefetchable) [size=16M] Memory at 50000000 (64-bit, prefetchable) [size=256M] Memory at 60000000 (64-bit, prefetchable) [size=32M] I/O ports at 5000 Expansion ROM at 63000000 [disabled] [size=512K] Capabilities: [60] Power Management version 3 Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [78] Express Legacy Endpoint, MSI 00 Capabilities: [b4] Vendor Specific Information: Len=14 <?> Capabilities: [100] Virtual Channel Capabilities: [250] Latency Tolerance Reporting Capabilities: [258] L1 PM Substates Capabilities: [128] Power Budgeting <?> Capabilities: [420] Advanced Error Reporting Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?> Capabilities: [900] Secondary PCI Express Capabilities: [bb0] Physical Resizable BAR Capabilities: [c1c] Physical Layer 16.0 GT/s <?> Capabilities: [d00] Lane Margining at the Receiver <?> Capabilities: [e00] Data Link Feature <?> Kernel driver in use: vfio-pci Kernel modules: nouveau, nvidia_current_drm, nvidia_current 01:00.1 Audio device: NVIDIA Corporation Device 228e (rev a1) Subsystem: eVga.com. Corp. Device 3656 Flags: bus master, fast devsel, latency 0, IRQ 17, IOMMU group 1 Memory at 63080000 (32-bit, non-prefetchable) [size=16K] Capabilities: [60] Power Management version 3 Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+ Capabilities: [78] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [160] Data Link Feature <?> Kernel driver in use: vfio-pci Kernel modules: snd_hda_intel 02:00.0 PCI bridge: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA (rev ca) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 129, IOMMU group 1 Memory at 65500000 (32-bit, non-prefetchable) [size=256K] Bus: primary=02, secondary=03, subordinate=06, sec-latency=0 I/O behind bridge: 00003000-00004fff [size=8K] Memory behind bridge: 65100000-654fffff [size=4M] Prefetchable memory behind bridge: [disabled] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable+ Count=1/8 Maskable+ 64bit+ Capabilities: [68] Express Upstream Port, MSI 00 Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA Capabilities: [100] Device Serial Number ca-87-00-10-b5-df-0e-00 Capabilities: [fb4] Advanced Error Reporting Capabilities: [138] Power Budgeting <?> Capabilities: [10c] Secondary PCI Express Capabilities: [148] Virtual Channel Capabilities: [e00] Multicast Capabilities: [b00] Latency Tolerance Reporting Capabilities: [b70] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?> Kernel driver in use: pcieport 03:00.0 PCI bridge: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA (rev ca) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 130, IOMMU group 1 Bus: primary=03, secondary=04, subordinate=04, sec-latency=0 I/O behind bridge: 00004000-00004fff [size=4K] Memory behind bridge: 65300000-654fffff [size=2M] Prefetchable memory behind bridge: [disabled] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable+ Count=1/8 Maskable+ 64bit+ Capabilities: [68] Express Downstream Port (Slot-), MSI 00 Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA Capabilities: [100] Device Serial Number ca-87-00-10-b5-df-0e-00 Capabilities: [fb4] Advanced Error Reporting Capabilities: [138] Power Budgeting <?> Capabilities: [10c] Secondary PCI Express Capabilities: [148] Virtual Channel Capabilities: [e00] Multicast Capabilities: [f24] Access Control Services Capabilities: [b70] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?> Kernel driver in use: pcieport 03:08.0 PCI bridge: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA (rev ca) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 131, IOMMU group 1 Bus: primary=03, secondary=05, subordinate=05, sec-latency=0 I/O behind bridge: [disabled] Memory behind bridge: [disabled] Prefetchable memory behind bridge: [disabled] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable+ Count=1/8 Maskable+ 64bit+ Capabilities: [68] Express Downstream Port (Slot+), MSI 00 Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA Capabilities: [100] Device Serial Number ca-87-00-10-b5-df-0e-00 Capabilities: [fb4] Advanced Error Reporting Capabilities: [138] Power Budgeting <?> Capabilities: [10c] Secondary PCI Express Capabilities: [148] Virtual Channel Capabilities: [e00] Multicast Capabilities: [f24] Access Control Services Capabilities: [b70] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?> Kernel driver in use: pcieport 03:09.0 PCI bridge: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA (rev ca) (prog-if 00 [Normal decode]) Flags: bus master, fast devsel, latency 0, IRQ 132, IOMMU group 1 Bus: primary=03, secondary=06, subordinate=06, sec-latency=0 I/O behind bridge: 00003000-00003fff [size=4K] Memory behind bridge: 65100000-652fffff [size=2M] Prefetchable memory behind bridge: [disabled] Capabilities: [40] Power Management version 3 Capabilities: [48] MSI: Enable+ Count=1/8 Maskable+ 64bit+ Capabilities: [68] Express Downstream Port (Slot-), MSI 00 Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8724 24-Lane, 6-Port PCI Express Gen 3 (8 GT/s) Switch, 19 x 19mm FCBGA Capabilities: [100] Device Serial Number ca-87-00-10-b5-df-0e-00 Capabilities: [fb4] Advanced Error Reporting Capabilities: [138] Power Budgeting <?> Capabilities: [10c] Secondary PCI Express Capabilities: [148] Virtual Channel Capabilities: [e00] Multicast Capabilities: [f24] Access Control Services Capabilities: [b70] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?> Kernel driver in use: pcieport 04:00.0 Serial Attached SCSI controller: Broadcom / LSI SAS3008 PCI-Express Fusion-MPT SAS-3 (rev 02) Subsystem: Broadcom / LSI SAS 9300-16i Flags: bus master, fast devsel, latency 0, IRQ 17, IOMMU group 1 I/O ports at 4000 Memory at 65440000 (64-bit, non-prefetchable) [size=64K] Memory at 65400000 (64-bit, non-prefetchable) [size=256K] Expansion ROM at 65300000 [disabled] [size=1M] Capabilities: [50] Power Management version 3 Capabilities: [68] Express Endpoint, MSI 00 Capabilities: [a8] MSI: Enable- Count=1/1 Maskable+ 64bit+ Capabilities: [c0] MSI-X: Enable+ Count=96 Masked- Capabilities: [100] Advanced Error Reporting Capabilities: [1e0] Secondary PCI Express Capabilities: [1c0] Power Budgeting <?> Capabilities: [190] Dynamic Power Allocation <?> Capabilities: [148] Alternative Routing-ID Interpretation (ARI) Kernel driver in use: mpt3sas Kernel modules: mpt3sas 06:00.0 Serial Attached SCSI controller: Broadcom / LSI SAS3008 PCI-Express Fusion-MPT SAS-3 (rev 02) Subsystem: Broadcom / LSI SAS 9300-16i Flags: bus master, fast devsel, latency 0, IRQ 18, IOMMU group 1 I/O ports at 3000 Memory at 65240000 (64-bit, non-prefetchable) [size=64K] Memory at 65200000 (64-bit, non-prefetchable) [size=256K] Expansion ROM at 65100000 [disabled] [size=1M] Capabilities: [50] Power Management version 3 Capabilities: [68] Express Endpoint, MSI 00 Capabilities: [a8] MSI: Enable- Count=1/1 Maskable+ 64bit+ Capabilities: [c0] MSI-X: Enable+ Count=96 Masked- Capabilities: [100] Advanced Error Reporting Capabilities: [1e0] Secondary PCI Express Capabilities: [1c0] Power Budgeting <?> Capabilities: [190] Dynamic Power Allocation <?> Capabilities: [148] Alternative Routing-ID Interpretation (ARI) Kernel driver in use: mpt3sas Kernel modules: mpt3sas 09:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 10) (prog-if 30 [XHCI]) Subsystem: Fresco Logic FL1100 USB 3.0 Host Controller Flags: bus master, fast devsel, latency 0, IRQ 17, IOMMU group 14 Memory at 65900000 (64-bit, non-prefetchable) [size=64K] Memory at 65911000 (64-bit, non-prefetchable) [size=4K] Memory at 65910000 (64-bit, non-prefetchable) [size=4K] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+ Capabilities: [70] Express Endpoint, MSI 00 Capabilities: [b0] MSI-X: Enable+ Count=8 Masked- Capabilities: [100] Advanced Error Reporting Kernel driver in use: xhci_hcd Kernel modules: xhci_pci 0a:00.0 Ethernet controller: Intel Corporation Ethernet Controller I225-V (rev 03) Subsystem: Intel Corporation Ethernet Controller I225-V Flags: bus master, fast devsel, latency 0, IRQ 19, IOMMU group 15 Memory at 65700000 (32-bit, non-prefetchable) [size=1M] Memory at 65800000 (32-bit, non-prefetchable) [size=16K] Expansion ROM at 65600000 [disabled] [size=1M] Capabilities: [40] Power Management version 3 Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+ Capabilities: [70] MSI-X: Enable+ Count=5 Masked- Capabilities: [a0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [140] Device Serial Number 88-c9-b3-ff-ff-bf-75-d6 Capabilities: [1c0] Latency Tolerance Reporting Capabilities: [1f0] Precision Time Measurement Capabilities: [1e0] L1 PM Substates Kernel driver in use: igc Kernel modules: igc
