to remove everything iocage related from the currently activated pool and then run iocage activate <pool of choice> to get it to activate on the pool of your choice.
As far as I understand it, cleaning will remove everything including any datasets for jail already created.
I wish I'd know this when I was setting it up originally as I deleted everything manually and it was a PITA. Note that I've not tried the first command myself and that you should read the man page to ensure you understand what you are doing first. Clearly I didn't take my own advice.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
