cdiddy
- Oct 3, 2017
FreeNAS-11.2-U7
Last night, I set up a new jail using CLI from putty, and everything went fine. Added several mount points, service was started up and everything was working properly.
Today, I used the FreeNAS GUI to stop the jail, and make a change to a mount point... and all of the mount points except one were incomplete... the incomplete ones will allow me to choose source and destination directories, but after i click SAVE, it's still the same incomplete entries. Trying to start the jail anyways results in
Obviously, my first instinct is to try to find the difference between the one that stayed correctly filled out, but could not tell what was different.
Here is the source/destination for the one that works (and i am afraid to attempt to edit it for fear that it too will become incomplete)
CORRECT ENTRY:
source = /mnt/POOL/share/config/app destination = /mnt/POOL/iocage/jails/app/root/config
EXAMPLE OF WHAT I WANT IN THE INCOMPLETE ENTRIES:
source = /mnt/POOL/share/#files/#photos destination = /mnt/POOL/iocage/jails/app/root/files/photos
EXAMPLE OF WHAT I ACTUALLY GET:
source = /mnt/POOL/share/ destination =
thinking that something was wrong with the GUI, i deleted the messed up mount points, SSH with putty, create a mount point, and start the jail using CLI... aaaaaannnnndddd.......
jail: mount.fstab: /mnt/POOL/share/: missing information
CORRECT ENTRY:
