I have the following: Several Linux based NAS with ext2/3/4 filesystems and now a FreeNAS box with zfs. I have a few shell scripts I run that use rsync for backup. After configuring a NFS share on FreeNAS, I need to run these scripts with FreeNAS as the target.
All the rsync commands run on the linux box fail. Specifically the rsync chmod fails with "failed operation - not permitted". I am using the rsync options "-av". So I started dropping the individual options and found that if I ran the command without the ptgoD options that this worked. Problem is that I need these options.
So, my question is: Are there incompatibilities between the linux rsync and the FreeBSD rsync. Maybe it is the underlying filesystems?
Am I missing something here?
Thanks, for any insight,
Perazim
Perazim
