Astraea
 - Sep 7, 2019
I have had my 3 QNAP devices for a while now and want to continue to the hardware but install TrueNAS on them instead of the QNAP QTS software. The devices that I have and plan to migrate are two TS-451s and a TS853A. I did do some testing on one of the TS-451 boxes and had no issues installing and running TrueNAS for a weekend using some spare drives. I did remove the QNAP DOM before installing TrueNAS to 2 USB flash drives in a mirror setup. Since then I have upgraded all three boxes to 16GB ram and have purchased 6 new ScanDisk 64GB USB 3.0 flash drives and I have a few extra (4 to be exact) USB flash drives in case any of them fail.
While I know installing to USB is no longer recommended I want to be able to use all the bays for storage drives until I have the funds to migrate to custom-built 4U storage servers. Are there any gotchas or other issues that I am no seeing in this setup or did not encounter in my weekend testing. I know I will have to migrate the data off the boxes before I can add them to TrueNAS and will then have to move the data back over. I also plan to move one box first and run it for a week before moving the next and then allowing both to run for 2 weeks before doing the last box as the first is storing VM backup data from Proxmox, the second is storing VM disk data from Proxmox and the third is my main data storage device.
