I have been running FreeNAS 9.3.1 (from Jan 2016) until now and someone gave me the crazy idea to upgrade to the latest 9.10 (June 07). I followed all the direction given to clear all my previous Jails in preparation for the new Jail Templates. Then I did the update and everything seemed to work smoothly, all my shares, iSCSI, network settings seemed to transition to 9.10. At this point everything looked great in 9.10 so I decided to reinstall the plugins I use on a regular basis (Plex, Owncloud, and Sab). I went through the GUI and installed Plex first and right after it finished installing the webui stopped responding and eventually displayed: "Sorry, an error occurred". I can ping FreeNAS and using nmap/netstat it looks like ports 80 and 443 are still open. I rebooted the nas multiple times and it comes back in the same broken state. I deleted the jails dataset, rebooted and the webui came back, everything was happy again.
I tried rolling back to 9.3, wiping the jails dataset again to reinstall the plugins and unfortunately that didn't work either. I tried an earlier saved configuration but no luck either same issue. So now i'm kind of to the point where i might need to restart from scratch. I'd appreciate any ideas! Resetting up all my iSCSI and shares would be painful :(
I looked through various logs in /var/logs didn't see anything jump out at me. I tried my jails with DHCP and a static IP. There really doesn't seem to be much more config items I can easily access through the webui. I can try some manual changes if anyone has any suggestions. When I shell into a jail i can ping my network.
My network is a bit complex: I have a 4 port LAGG (LACP) with 2 VLANs for multipath EXSI iSCSI mappings and a separate user vlans. I tried redoing all the network setting from scratch in 9.10 I didn't seem to get any different results. I tried DHCP and static IP for my user vlan no difference. I've never really had any issues with the complicated network config I set it up and it just seemed to work. Unfortunately, it would be a substantial effort to reconfigure the network to not use a LAGG and VLANs to eliminate those variables.
Any ideas would be greatly appreciated! Thanks!
System:
SuperMicro X8DTN+
72gb ECC RAM
IBM ServeRAID M1015
4x4tb HGST NAS drives
2x2tb WD Red NAS drives
120gig Intel x530 SSD for OS.
System:
SuperMicro X8DTN+
72gb ECC RAM
IBM ServeRAID M1015
